3 Flashers?
drosera88
Post by drosera88 »
[quote="fordman"]your not suppose to give the cat a bath in the sink. you do it in the toilet with the lid closed . and then flush it a couple of times.[/quote]
I wasn't even home when it happened!!! The sink was full of dishwater, and the cat must have thought the camera was a toy.... The cat is dirty however, Ill have to try your suggestion... :twisted: he he
i first heard that suggestion when i was in california back in 87? it was a austrian guy on the radio first thing in the mornings out there. he was funny.
68F250
re: 3 Flashers?
Post by 68F250 »
Question: do your brake lights work properly right now? And when you plugged in the flasher and stepped on the brakes, do they come on first for a few seconds before going off and then coming on again?
Also a note, Ford wiring color code says white with a blue stripe wire means right front turn signal and right turn signal indicator in cluster, go figure. :hmm:
Barry
drosera88
re: 3 Flashers?
Post by drosera88 »
They work properly only when the flasher is not in the third plug, and yes they do go on before blinking.
I traced the wires, and rather than explain it, I'll show it. Here is a picture, courtesy of the "Factory Wiring Diagrams" section of Fordification that I have modified to try and show where I traced the wires and where the plug is at.
*See attachment*
As you can see by the red question marks, I am unable to trace where the wires go past a certain point (I could cut open the wrapping, but I'd rather not). Interestingly, the wire near sockets G and F completely bypasses the sockets.
I thought this would clarify things, but, after tracing the wires, I think the mystery has only deepened.
rjewkes
Post by rjewkes »
looks like somebody has altered your harness either they moved the warning light switch to your dash or they wired in a backup one in the glovebox.
You know incase the driverside is beat in so bad that although they survive the crushing forces involved in that they can only reach in the glovebox.
fuelly.com
iwould ignore it it is probably for the headlights or what kieth said about that box.
drosera88
re: 3 Flashers?
Post by drosera88 »
Yeah, I decided to open the neat wrapping (whoever did it, did a good job, it looks factory) around the wires and found that the plug had been spliced into other wires. What for, I have no idea, so I just removed it. My turn signals still don't work though....dang....
Thanks for the help though!
its got to be in the column wiring.
