Bypass Park/Neutral switch
4x4_Welder
Post by 4x4_Welder »
I may have to go to a floor shifter in the very immediate future, so I'll have to ditch the safety switch. For a 69, what two wires get crossed to make it work?
Sharkdance
re: Bypass Park/Neutral switch
Post by Sharkdance »
My 70 had a floor shifter and the NSS was bypassed. I gave that column to Wideguage so if you contact him he could tell you which two wires were crossed to make it work.
I do remember, of the 4 wires on that switch it was two that were right next to each other so you got a 50/50 chance if you just take a stab at it. :lol:
One thing I would recomend is: if you do bypass the NSS run those two wires to a toggle switch or something so you dont accidentaly start you truck while its in gear. (Long story on how I learned this)
At least with a toggle, you have to think about it before you turn that key.
Ive been searching for a way to hook up a NSS to my existing floor shifter.
Ill have that worked out before I start my truck back up after my cab swap.
Sharkdance
70 F250 2WD 360/C6
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Why not just unbolt the NSS from the column and then tie it in the open position? You could then just tie it up out of the way until you get your present column fixed, so that when you do you won't have jury-rigged wiring to have to undo.
yeah you could tie it open. but i think the two wires are black with red with a blue stripe. i think.
4x4_Welder
I'm not too worried about starting in gear, I'm putting a 5speed in it later, and I just need to bypass the switch so I can make it start with the console shifter. I still need to find a way to make the backup lights work automatically.
Ford_Doctor
Post by Ford_Doctor »
Your wire colors are:
  • Crank Signal Input- Red/Green
    Crank Signal Output- Blue/Green
These are at the safety switch, and as far as the back-up lamps just run those on a toggle until you get your new trans in.
460 crew
Post by 460 crew »
Isn't there a jumper wire that is located on the driverside inner fender for the stick applications, in an auto it is replaced by a plug that runs into the cab for the switch on the column?
Fake Name
Post by Fake Name »
jared- you have another PM waiting for you unrelated to this thread...
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
xxxtina63
Post by xxxtina63 »
Can't help you. All of mine are red. Someone at one time cut and re-wired the entire dash. And yes, mine will start in gear with a C6- and move! Yeah, don't ask.
4x4_Welder
I hunted it out with my fluke meter. At the plug, it's the two red/ dark stripe wires next to each other. I just clipped them together with a scotch-loc, it starts now. Once I get the console finished, I'll post some pics.
