Shift lever stuck
Ron_Hall
Shift lever stuck
Post by Ron_Hall »
Hi guys, I have a little problem. Installed my steering column today and now the selecter won't go past the neutral. :cry:
I disconnected the shift lever and it makes no difference. Park, reverse and neutral seem to be ok.
What would be the most obvious thing to look for?
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
Bill Ramsey
Re: Shift lever stuck
Post by Bill Ramsey »
check the neutral safety switch. the little tab thingee might be hung up.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
Ron_Hall
Post by Ron_Hall »
Bill Ramsey wrote:check the neutral safety switch. the little tab thingee might be hung up.
Hi Bill, I think you hit the nail on the head!! I looked a while ago and I have the nss arm on the wrong side of the selector thingee. :D
Ron
One owner...
