9” center section with 8.7 gear
Ok, Help please. Is my research understanding correct. Are all the components/parts, 9” differental parts, except the ring and pinnon?
- Manny
Re: 9” center section with 8.7 gear
WSWRANGER wrote:Ok, Help please. Is my research understanding correct. Are all the components/parts, 9” differental parts, except the ring and pinnon?
9 inch is a 9 inch all the junk swaps you just have ring and pinion ratios and then open limited slip and such differentials.
[image][/image]
- 67mann
This might clear up some of your Q's http://kevinstang.com/Ninecase.htm
