Frozen brake line flare nut
I've dealt with rusted bolts before, but this one has me stumped. I decided to replace a brake line on the F250 because I couldn't get one of the flares to seal. I got the wheel cylinder side to come loose, but the end that connects to the distribution block is totally frozen. A six point socket rounded the corners, and a very tight set of sharp vice grips just keeps shaving off layers of metal. I've used PB Blaster, and a torch. The sucker will not budge. Any suggestions?
Re: Frozen brake line flare nut
Well its time to replace the line so just cut through it and make a new one.
1967 F-100 4x4 custom cab.
Try tapping a smaller metric 6 point ( 9mm ?) on and see if that grabs.Clunker wrote:A six point socket rounded the corners
or it might be time for a new flex line / distribution block.
A small pipe wrench will remove it.
Ah yes! A pipe wrench. I'll give that a shot, but there is very little room between the flare nut and the axle housing. Thanks for the suggestion.
Pipe wrench worked. Still took a lot of force to turn it. I can't believe the nut didn't break. Thanks again.
Great.
- eggman918
Acetone and ATF 50/50 is the best thing for stubborn rusted fasteners but you will need to shake it up before use as it tends to separate after sitting.
- Ron_Hall
This is cool..!
https://www.summitracing.com/nv/parts/o ... -otc-tools
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
One owner...
