Body swap to a 4x4
77Ranger
Re: Body swap to a 4x4
Post by 77Ranger »
My f150 has a c6 automatic with 400 in it. The f250 has automatic (I assume c6) and 390 in it.
cep62
Post by cep62 »
:wel:
Welcome to the site, there's a lot of info here.
The post you responded to has 3 pages of conversation that should answer your questions.
If you have a more specific question , feel free to post it in one of the above categories.
hazelnut
Post by hazelnut »
I don't know what frame perches a 400 takes so hard to say what you will need to bolt in the 400 in place of the 390. They are 2 different engine family's and you'll probley have to change a lot to make a 400 work. Would be a lot simpler to find a different 390 to put in the truck.
HIO Silver
Post by HIO Silver »
77Ranger wrote:I don't mean to butt in but but I have a 77 f150 2wd. I have come across a 76 f250 4x4 truck with no bed,shot cab, bad motor, good trans good transfer case. Can I just put my body and motor on the 250 frame to have 4x4?
Otherwise than the high/low hump issue the body is a straight swap.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
