I really didnt know what i wanted to do, but i pictured it being lowered, on nice rims.... Did some research, and vic suspension shouted... *BUY ME!* One half off junkyard day and $180 later..
Split these two up, the c6 got a front and rear seal, and new filter. old filter screen wasnt that bad lookin. painted pan and tube for good measure.
The fe however, got checked out, thought about putting 390 rotating assem. in it but firgured i should leave it alone. Cross hatching is great! Might have been bored over, the markings on the vally mean it must have been machined once from what some say. I plan on a comp thump cam, lifters, and timing chain kit. 4 barrel something or other 600-650cfm, headers.
Cab has rot! insted of goofing around with fabbing outside on the frame, we pulled it off and put it in the garage. GEEZ, easier said then done, i envy peoples two post lifts now. Made a little sub frame for it to sit on from 2x2".
Off with the bed! Calling it junk due to needing quarter on passenger, floor, bottom supports, and tailgate.
Cab time! Cut out the old floor pan from the replacement pan's tracing, and did a bunch of kick panel patching. Urg! Not quite done on the drives ATM.
And got these, 2012 mustang v6 preminum 18's for it. Traded some stuff for it. bad thing is the back spacing is a good amount, but im running adaptors on the IRS so that should space things good, and track damn good with how wide the front is.
Now... Getting up to date! I got this MN12 for $150, from a SC model. Bigger brakes. Trac lok 2L73's. The IRS will be a combination of the two. Aluminum 8.8 with 3.07's and lower control arms from a lincoln irs setup, and this one had coils, witch i thought they all had air bags, huh. Going to be putting the trac lok in the lincolns 8.8 and the arms on the subframe. The t-birds disk brakes are a good 1/4" wider ventilated then the stock lincoln disks, witch is a little odd, but better, me thinks.
Going to be making all my own mounts for this, seems pretty "easy". but i need two front mounts and cant find anything, ill try a dealer.
Welp! Lots of pictures, ooooo, ahhhh... Pictures from april to now so not exactly SEMA speed building... LOL, only 17 fab everything myself, workin with junkyard and CL parts. Enjoy!
