445 Stroker Dyno results
67fordkc
Post by 67fordkc »
Had my 67 445 stroker dyno'd this week and wanted to post the results.
rltvader
Re: 445 Stroker Dyno results
Post by rltvader »
I have been considering making a 445 FE, what did you do to it to get that power?
-Built Ford Tough for a Reason
1969 F100 Red/White LWB (302)
1972 F250 Camper Special Ranger White LWB (FE)
67fordkc
Post by 67fordkc »
Barry with Survival built this for me, see below for the list parts, I still need to get the cam specs from Barry.
holley 800 cfm double pumper,
doug thorley headers,
msd distributor,
msd 6al ignition,
Heads - Edelbrock stage x - Stainless Valves,
Scat cast crankshaft - 4.250 stroke
Scat I beam connecting rods - 6.700 long
Forged pistons - Dished 9.8:1
Cam & Lifter package - Hydraulic Roller
Intake Manifold - Edelbrock Performer RPM
Roller Rocker Arms
3.73 Dana 60, 5 lug rear end with 4 sp top loader.
Here is link to the dyno run.
http://youtu.be/gQbu7gxXSWY
I am very happy with the performance........ :D
Mike R
Post by Mike R »
I'm runnin just about the same setup but I am having trouble with my throttle linkage, can you post a picture or email me a picture of yours? Probably also good to know if you needed extra parts too...
Theeeeeeere ya go!
In Progress:
'67 F250 Custom Cab Camper Special "Cecil"
1969FordMan
Post by 1969FordMan »
what exhaust pipe size did you run?????? I am pricing a similar 445 from survival, I may go ahead and get the exhaust setup this fall, though it will be a while before I can order the engine.
1969 F100. All factory 360, 4-speed, candy apple red one owner. Incredible truck!
67fordkc
Post by 67fordkc »
1969FordMan wrote:what exhaust pipe size did you run?????? I am pricing a similar 445 from survival, I may go ahead and get the exhaust setup this fall, though it will be a while before I can order the engine.
2 1/2 with flowmaster 44's and H pipe
Mike R wrote:I'm runnin just about the same setup but I am having trouble with my throttle linkage, can you post a picture or email me a picture of yours? Probably also good to know if you needed extra parts too...
I will get you a picture tomorrow and post it for you.
My427stang
Post by My427stang »
Looks great, I should be able to fire my 445 next weekend. I can't wait, after I built my 489 FE, I fell in love with these FE strokers. Your 445 sure shouldn't disappoint!
My427stang
Did you ever get your cam specs?
Interested in what you used compared to mine
elgemcdlf
Post by elgemcdlf »
What kind of money do you have invested for 353 hp? Seems like a lot of work/money for 353 hp. Is the trade off in weight? I have always heard FEs were light, weight wise.
HIO Silver
Post by HIO Silver »
'gotta keep in mind it's 353 RWHP..... and dyno results vary from machine to machine, ambient conditions, plus losses from parasitic drivetrain loss.
Here's an article for your interest: http://www.hotrod.com/techfaq/hrdp_0405 ... ewall.html
hotrodfeguy
Post by hotrodfeguy »
Yes you may be at 350 375 HP on a chassis dyno but look at the TQ you are putting down MY GOD man. Chevy guys would kill for numbers like that on an engine that weighs that much. FE's come across the scale at nearly the same as a SBC.
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
e6ug
Post by e6ug »
nice!!!! 445 stroker is definitely on my wish list.
67fordkc
Post by 67fordkc »
My427stang wrote:Did you ever get your cam specs?
Here are the cam specs:
110.00 intake center line
Intake Exhaust
Duration @.050 234 240
Lobe lift .3380 .3400
Lobe Separation 112.0
That is a relatively mild camshaft for a 445 ci motor.
mrtleavitt
Post by mrtleavitt »
Nice numbers! It's amazing what a stroker crank will do to those torque numbers. I have a built 428 with 338 hp and 383 tq at wheels. I soooo wish I would have went with one of those 4.25 Scat cranks. :thup:
