Vacuum advance
whiteblur
Re: Vacuum advance
Postby whiteblur » Sat Jun 18, 2011 12:12 am
forrestbump wrote:My guess is your vacuum advance line is connected to the ported vacuum tube, I've followed Woods' advice and connected mine to the direct port, readjusted my carb and admit it's running much better.
mine is connected to the vacuum advance line and yours is to the direct port :? not understanding
forrestbump
Re: Vacuum advance
Postby forrestbump » Sat Jun 18, 2011 12:20 am
There are usually two vacuum ports (metal tubes) in the front of carbs. The higher port (tube) is called a timed port as it is affected by butterfly movement. The lower port (tube) is a direct source of vacuum and is NOT affected by butterfly movement.
Most carb suppliers recommend using the timed port, but after reading Woods' (he's a very knowledgeable member here) posts in the "Mileage Quest" thread found in General Discussion, I've changed my thinking and now recommend using the direct port location as the proper source for vacuum advance canisters.
1970, 2WD, F-250, C/S, Dual Tanks, 390 FE (of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Sky View Blue, Ranger XLT
1970, 2WD, F-250, C/S, A/C, Dual Tanks, 390 FE (again, of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Wimbledon White & Sky View Blue, Ranger (almost twin brothers!)
"One of the greatest discoveries a man makes, one of his great surprises, is to find he can do what he was afraid he couldn't do" - Henry Ford
Larry
tmcalavy
Re: Vacuum advance
Postby tmcalavy » Sat Jun 18, 2011 7:01 am
I think a picture is worth a thousand words in this situation...don't have an I-6 anymore, so can someone post one showing him the vacuum line routing? He is unfamiliar with our/your terminology.
woods
Re: Vacuum advance
Postby woods » Sat Jun 18, 2011 10:44 am
It may be a bad vac can like mentioned above. It may also be pulling in too much timing OR if the plate your points sit on is worn out, the vac advance can pull it at an odd angle which can change your point gap. Fix the vac leak and fix whatever is going on with your distributor. Running "fine" is really up to personal interpretation. With a vac leak and no vac advance...I can tell you without even driving it, that I personally would not think it ran fine. In other words, if you think it runs good now, you will be amazed at how it can run when everything is correct.
Whateverman
Re: Vacuum advance
Postby Whateverman » Sat Jun 18, 2011 11:32 am
it may run "fine" idling in the driveway and revving it up with the vac advance off, but it'll end up pinging and knocking its way up the road ,especially if you run into any hills- not to mention backfiring ,stumbling and stalling
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
Re: Vacuum advance
Postby fordman » Sat Jun 18, 2011 11:47 am
there is some thermactor type of vaccum routing on this page. that may help. http://www.fordification.com/tech/schematics_e.htm
whiteblur
Re: Vacuum advance
Postby whiteblur » Sat Jun 18, 2011 3:27 pm
i checked the vacuum can and it all seems to be good. I took it for a drive around the neighbor hood with the other port open and the vacuum advanced hooked up and it stumbles and the exhuast pops and when you slow down or push in the clutch if you dont give it gas, it'll die
woods
Re: Vacuum advance
Postby woods » Sat Jun 18, 2011 4:31 pm
First...no vacuum port should be uncapped.
Now take your distributor cap off and slide the plate your points sit on toward the way the canister pulls it. Is it loose? Does your point Gap change from one position to the nest even though they are on the high spot of the cam?
tmcalavy
Re: Vacuum advance
Postby tmcalavy » Sat Jun 18, 2011 9:24 pm
Unless I missed something...wish we knew which carb you have so someone can tell you how may vacuum hookups you have and which ones should be capped and which one connects to the distributor. Until then, who can say?
whiteblur
Re: Vacuum advance
Postby whiteblur » Sat Jun 18, 2011 10:58 pm
Carter yf manual choke
tmcalavy
Re: Vacuum advance
Postby tmcalavy » Sun Jun 19, 2011 8:54 am
Try this on for size:
http://oldcarmanualproject.com/manuals/ ... /index.htm
It's been too many years for me to remember the exact YF vacuum routing.
If the link above doesn't help do a Google search for Carter YF manual choke vacuum diagram and see what you get.
You may have a PCV vacuum connection on the manifold under the carb, and for sure one vac port on the carb that goes to your distributor...but can't remember where you attach the power-brake booster vac line on your setup. Hang in there, you're getting closer.
happycamper
Re: Vacuum advance
Postby happycamper » Mon Jun 20, 2011 11:37 pm
vacuum advance is supposed to go to a "timed" vacuum port; not a full-time/full manifold vacuum port. If it is hooked to full manifold vacuum, you will be running "advanced" all the time. Just went through this with Holley tech support. My :2cents:
'72 Ranger XLT CS, 2013 C-Max, 2012 Ram 3500 4x4 Cummins H.O.
woods
Re: Vacuum advance
Postby woods » Mon Jun 20, 2011 11:54 pm
Holley tech is wrong (just so you know). I don't want to go through all this over again. Please read this.
http://www.fordification.com/forum/view ... &start=120
Fo-Mo-Co
Re: Vacuum advance
Postby Fo-Mo-Co » Tue Jun 21, 2011 7:54 am
woods wrote:Holley tech is wrong (just so you know). I don't want to go through all this over again. Please read this.
I second this. I won't go into all the BS I have gon through but Woods is correct Holley is wrong.
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
tmcalavy
Re: Vacuum advance
Postby tmcalavy » Thu Jun 23, 2011 5:06 pm
I followed woods' link to the other thread and got caught up there with my reading...went out after work today and hooked my dist. up to manifold vacuum on the rear of the 360 in my 69 F250...there's a splitter there. Also plugged the port on the carb that I was using, and really like the engine response now. Like he says, it wakes your engine up. I'll know in a week or so if it makes a difference in mpg...I'm getting 12.7 in town driving right now.
Return to “Engine”
