radius arms interchangeable
Re: radius arms interchangeable
I've been using a wire wheel all day and priming and painting them. Will have the final product pics later tonight
- forrestbump
Yup!whiteblur wrote:my 67's should fit
When you tighten the fastener down (the nut that fastens the tie rod to the steering knuckle for example), it keeps the rubber boot in place.whiteblur wrote:i noticed they seem to just slide on......how do you keep them slid up??
The main function of the rubber boots is to keep large pieces of debris out of the tie rod end, they're not snugly fitted to the tie rod end by design.
1970, 2WD, F-250, C/S, Dual Tanks, 390 FE (of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Sky View Blue, Ranger XLT
1970, 2WD, F-250, C/S, A/C, Dual Tanks, 390 FE (again, of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Wimbledon White & Sky View Blue, Ranger (almost twin brothers!)
"One of the greatest discoveries a man makes, one of his great surprises, is to find he can do what he was afraid he couldn't do" - Henry Ford
Larry
Larry
- F100builder
I just did this but I used DJM's 3" dropped beams.
http://www.fordification.com/forum/view ... =5&t=58678
From a '75 donor...
-booster
-proportioning valve
-front brake hose brackets
-spindles
-radius arms
-coil springs
New replacement parts for a '75 (new kingpins included with DJM beams)...
-master cylinder
-rotors
-calipers
-pads
-bearings/seals
-brake hoses
and then I bent up all new hard lines.
From a '75 donor...
-booster
-spindles
-radius arms
-coil springs
-master cylinder
-rotors
-calipers
-pads
-bearings/seals
-brake hoses
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
That truck is so good looking!!! Mine will be about what yours is:) i repainted everything and im going to install the stuff today
to bad my drive way isnt flat haha
- F100builder
Thanks a bunch! My driveway isn't exactly flat but I felt it was flat enough to do what I was doing. Believe me...I don't just crawl around under a vehicle without being 100% sure it's not going to move anywhere!
Good luck on yours and have fun doing it!
Let's see some pics when you're done too!
Patrick
sound good bud. got one side one and almost the other except were having a little trouble with the other i beam going into the hole
so i took a supper break
well im all done except brake lines and re-installing tie rod ends
Cant tell yall enough how much yall have helped making this all go bye so easy. I really do appreciate all the help. Believe me the project wont stop at just a disc brake swap, now what fun would that be? Haha. well here are some photos. THANKS!!!
the 74 set up painted
old 67 drum set up removed
drivers side installed with a little help from my buddy drawing on the rotor he turned for me
all done
(dad in the back ground and the bow tie behind the ford)
all done
- F100builder
Nice work and lookin' good!
Man, I bet it was nice to do this job with the front clip and motor out of the way!
Patrick
oh yeah! i was debating on weather or not to put the motor back in first or not and decided not to. i wont put it back in until brake lines are done.
