Idles good but dies when in gear...complete engine rebuild
Florian
Re: Idles good but dies when in gear...complete engine rebuild
Post by Florian »
Is there any wiring to be done for the electronic choke?
1971 Ford F100, 302cui, 3 on the tree
Dragon
Post by Dragon »
Florian wrote:Is there any wiring to be done for the electronic choke?
I wire to the high idle solenoid connector at the fire wall. The only requirement is the choke must not be tied into the resistor wire or the coil wire after the firewall and must be only turned on if the switch is in run.
Old Fords Rule
Was a Ford Service Tech
71 F250 with Shell Car 390 NP435 Dana 60 3.73s, PS, PB, 750 EC VS Holley Accel Points Eliminator.
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
Florian
Post by Florian »
Hmmm...I think I´ll stick to the manual choke. I drove mine with the manual choke for the last few months and never had problems, also got decent fuel mileage. Also I won´t drive over the winter months so I won´t start in very cold temperatures.
I talked to a car guy from here yesterday. He said that Edelbrock carbs were easier to tune and offer very good street performance. The Holley carbs, he ment, were more difficult to work on but deliver more performance in the high rpms.
I don´t know, but I don´t have any experience with tuning carbs, but I´d sure like it to be easy to do it myself. :hmm: Are the Holley really harder to set up than the Edelbrocks?
I´d rather have a good street carb that I can tune myself than a over complicated high performance carb that makes a bit more power.
Thanks!
Florian
Florian
Post by Florian »
Damn...just called the machinist. They checked the heads and said that the valve guides were not the best anymore. Also I should go with new oversize valves. All in all their work would cost about $800. Plus the parts! New valves plus new valve guides plus new valve seats ... at least $500 :cry:
Other option are new heads now..
Which heads would you guys recommend me for the 332 stroker set up?
Here are the heads I came up with the information I have:
http://www.summitracing.com/search/Depa ... =Price|Asc
Thanks!
Florian
Dragon
Post by Dragon »
The holley is way easier to tune. 4 jets 1 power valve 2 floats 2 idle needles. Oh and for the most part they don't get tuned out of the box. Edelbrock 4 jets 4 needles 1 power valve 2 idle needles. I have worked on both and nothing is easy on Edelbrock. 4 screws and reusable gaskets on a holley for jet changes, power valve changes. 12 on Edelbrock, 1 screw if the float needs work 12 if the Edelbrock float needs work. Dirt in the carb 8 screws to clean a Holley 12 one an Edelbrock and most times an Edelbrock top is removed you need a new gasket.
http://www.summitracing.com/parts/FMS-M-6049-X307/ My choice Street designed for Hot street performance.
http://www.summitracing.com/parts/EDL-60399/ 2nd choice, Copied the Ford design of old.
The other heads are high rpm large ports and so on low flow at street rpms.
Old Fords Rule
My Gallery
Spark test
Florian
Post by Florian »
Thanks Dragon!
What about the other GT-40 heads with 64cc combustion chamber, would that be too large?
Florian
Post by Florian »
I chatted with a guy from Summit, because I wanted to ask if the GT-40 heads really aren´t available before 8/23. He didn´t think so but he said that the GT-40 heads have springs for hydraulic roller cams, not for hydraulic flat tappet cams and that I would have to change springs if I want to run the Crower Baja Beast cam.
Is that true? The Summit guy recommended me the Edelbrock E-Street heads:
http://www.summitracing.com/parts/EDL-5023/
or http://www.summitracing.com/parts/EDL-5025/
Dragon
Post by Dragon »
Florian wrote: What about the other GT-40 heads with 64cc combustion chamber, would that be too large?
64s would be good to keep you out of the need for Premium fuel.
Of the 2 Edelbrock heads this one would do you the best.
Think of this if Ford Racing found that the Edelbrock heads were better than the GT 40 heads then they would license the design. They didn't. A modern GT 40 is a street Hot Rod. The springs would not even care that you had a light cam compared to stock. Yes a GT 40 cam is a roller and way more radical than the Crower so the springs handle more abuse, a little more lift and will work fine.
Old Fords Rule
My Gallery
Spark test
Florian
Post by Florian »
That´s an aspect I didn´t think about before! I really don´t want to need to use premium fuel only!
With the old setup I used unleaded 98 octane Super-Petrol with lead substitute. So with a bigger combustion chamber I won´t need premium fuel or what? Do I still need the lead substitute then?
That means that the GT40 springs are harder? Wouldn´t that cause faster wear of the camshaft, because of higher pressure on it? Do I need new pushrods with more lift to clear the stronger springs then?
Florian
Post by Florian »
Which pushrods would I need for the GT-40 heads? Do they differ in lenght etc?
Which pushrods would I need for the E-Street heads, at the Summit product page it says that hardened pushrods are required.
With the Performer heads I could reuse my old pushrods, is that right?
Dragon
Post by Dragon »
They want hardened pushrods because the heads are sloppy and the tubes might touch.Hardened refers to the pushrod side wall. You adjust the rockers for a fit on the 302. Even on FEs when we go performance it is easier to get adjustable push rods or convert to adjustable rockers than deal with different length pushrods.
GT-40 and stock are the same length.Requires head bolt kit and bushings on this engine. For 1968 and up.
The Edelbrock kit requires. Requires head bolt bushings, sold separately. Fits 1982-95 stock bolt-down rocker arms.
Old Fords Rule
My Gallery
Spark test
Florian
Post by Florian »
Dragon wrote:You adjust the rockers for a fit on the 302.
So for the Edelbrock 60399 Performer heads I can reuse my old pushrods and also my old rockerarms. But I would need new head bolts (Edelbrock 8552) and bushings (Edelbrock 9680).
Is that right? Anything I forgot? I just want to make sure I´ve got everything when I order parts because shipping is expensive.
Thanks!
Florian
cdeal28078
Post by cdeal28078 »
Nearly all aftermarket type heads use roller rockers that require guide plates and hardened push rods. In the picture that is what these heads look like to me. Might be wrong though. Seems like I am a lot. lol
Newer Ford heads use stamped steel rocker arms that are just bolted down.
I doubt you can use your rockers or push rods on after market heads. You old rockers had a lip on the underside that kept the rocker lined up on the valve tip. Roller rockers don't have them which is why they use the guide plates and the hardened push rods. Only reason for hardened push rods is they use the guide plates to keep the rocker arms centered on the valve top.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Dragon
Post by Dragon »
You can use any rocker with the GT and Edelbrock heads. Though Guide plates are required if you use a ball type rocker because the rocker will turn sideways if the push rod moves sideways. If the heads required a special rocker the page would tell you. See there is two apps and they say different things on the application page 69 to 95 and 68 to 95. That tells me the stock parts from 68 will fit. Also the change over at Ford from 69 and up will fit if the blah blah blah is used.
Old Fords Rule
My Gallery
Spark test
Florian
Post by Florian »
Okay then I´ll try out my old rocker arms before I go get new ones.
Can you guys think of any other things I need for my rebuild?
One thing came to my mind, which assembly lubricant or -type is the best? And should I invest the fifty bucks for a one piece Fel Pro oil pan gasket rather than the one that comes with the Fel Pro gasket set?
Thanks!
Florian
