bumps with lowered altitude!! (lots of great custom bumps!!)
19FORD67
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
Post by 19FORD67 »
Hey, just curious, the 428CJ wasn't launched until '68?
:fr:
'67 352 3spd 3.25 9" Custom Cab
'92 Mercury Cougar
http://www.fordification.com/galleries/ ... ?pos=-3222
BobbyFord
Post by BobbyFord »
19FORD67 wrote:Hey, just curious, the 428CJ wasn't launched until '68?
April of 1968
Quick69
Post by Quick69 »
sport71 wrote:I can finally post mine. Even though it's not extremely low, it is lower than it was stock...
[ Image ]
[ Image ]
did you just cut your coils or beams????
1971 F100 Ranger XLT
302/C4/3.25
3/4 homemade drop
killakobra
Post by killakobra »
427blackpearl wrote:got a shop pass sat. and put new wheels and tires on. there 15x8 and tires are 235x75. plus i cut the front springs
[ Image ]
[ Image ]
[ Image ]
[ Image ]
how much did you cut off?
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
sport71
Post by sport71 »
[ Image ]
[ Image ]
No, I got the dream beams for the front, and for the rear I fliped the front spring hanger, and shimmed the axel to level it. You'll also need lowering shocks. The rear was the best way because I have the full suspension. If you need more help give me a PM. :wink:
Those who do not learn the lessons of history, are doomed to repeat it.
Quick69
Post by Quick69 »
thanks for the info, truck looks great
302/C4/3.25
3/4 homemade drop
JG F100
Post by JG F100 »
two more, both have mustang II IFS...
72 F100 - SWB conversion w/05 crown vic IFS, 8.8 rear w/disc, 20s, 360FE w/overdrive
Project Page: http://www.fordification.com/forum/view ... 22&t=37897
JG F100
Post by JG F100 »
Jaguar xj6 front suspension on this one
quantumleap
Post by quantumleap »
JG F100 wrote:Jaguar xj6 front suspension on this one
[ Image ]
[ Image ]
i coulda swore i read about this truck having drop beams and dearched springs out back? :hmm:
Daniel--67' reg cab black shortbed/fe/4spd/ford 9
quantumleap
hey jg f100...whose truck is that first primered one with the mustang2? not too shabby at all
JG F100
Post by JG F100 »
[ Image ]
[ Image ]
You are probably right, jag ifs is listed as "plans"
Here is that blue one again, guessing 17 or 18s wheels. Wish I could attend some of these shows...
tybob81
Post by tybob81 »
I wish I could see that blue one right above. Looks like a dent hood on it.
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
marz68
Post by marz68 »
The blue and black primer one are bad a$$!!
quantumleap
they truly are...i often wonder what it would be like to sit eye to eye at a stoplight with some cars..until then ill just ride up high like a big rig :cry:
Quick69
Post by Quick69 »
just lowered mine last weekend
1/2 flip on rear
1 1/2 coil cut on front
302/C4/3.25
3/4 homemade drop
