Here it is as of this afternoon:
I did change spark plugs, plug wires, distributor cap and I adjusted the idle speed screw. Timing chain hasn´t been changed, also don´t think that the PO ever changed it.cdeal28078 wrote: ...has the timing chain ever been replaced that you know of?
What is the right compression for a 302cui smallblock?cdeal28078 wrote:the RIGHT compression it should run.
Yes the sound when turning the engine over is strange. Doesn´t sound as usual. Will pull the valve cover this afternoon.cdeal28078 wrote:You can one valve cover and turn the engine over to see if the valves move and check the cam but if the cam or timing chain is broken you should be able to tell by the way the engine sounds when turning over. It just won't sound right.
After we had filled some gas in the carb it spitted fuel back out, but not really backfired because it was unburnt fuel only. Maybe it was too much fuel we filled in?cdeal28078 wrote:If the timing chain skipped a tooth it will spit and sputter and back fire through the carb. or exhaust.
When I checked yesterday, the rotor of the distributor turned. I also had spark on the plugs, tested different wires, tested the coil to distributor wire, seems fine.cdeal28078 wrote:Easiest way to make sure the timing chain has not broken it to pull the distributor cap and have some body turn the engine over. If the rotor button turns the cam and timing chain are still together.
