69 F250 parking brake cable
kevfromwales
Postby kevfromwales » Thu Feb 18, 2010 1:17 pm
Hi guys
I've got a 1969 F250 here - it's my new baby, but it has a slight braking issue!
(it's a 131" wheelbase, with the dana 60 rear axle)
- the problem is there is no cable between the foot operated parking brake (pretty unusual over here in the uk - very cool!) - and the 2 rear cables running into the drums - I do have the small metal yoke which supports the front ends of the rear cables - just the primary cable is AWOL
I've had a look on a few sites, and a place called LMC trucks list the cable in their online catalogue (page 117 - part no. 45-3826) - but is this definately correct for my truck?
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=115
- as I have seen a parts diagram somewhere on google (can't find it now!) which showed a hanbrake cable running into a sort of pivot bar with a big spring, before the rear cables??
I don't want to order the wrong cable!! - and to cap it all, even when I get the cable - the previous owner has welded a patch over the hole in the floor the cable runs through!! :?
cheers - kev
kevfromwales
Re: 69 F250 parking brake cable
Postby kevfromwales » Thu Feb 18, 2010 2:34 pm
found the parts diagrams I was looking at earlier - they are on this site!
- now I just need to know how to tell the difference between standard rear brakes and bendix BX type
- kev
Postby fordman » Thu Feb 18, 2010 6:30 pm
it doesn't show a difference for the front cable in brake size. they only show the one cable. the number you posted a link to. that is the cable. if you have nohting past the yoke except the rear cables and no little short cables and connectors you will need 2 of the 45-3900's and one of the 45-4066 springs which they dont list for your truck. i do have a spring from a 71 longbed though. but none of the other stuff (rod and keepers).
kevfromwales
Postby kevfromwales » Fri Feb 19, 2010 4:55 am
cheers fordman
bollocks! - looks like I'll need to order the rest of the linkage as well! - thanks for ID'ing the bits required
-kev
kevfromwales
Postby kevfromwales » Fri Feb 19, 2010 5:04 am
arrgghh! - more confusion - sorry about all this!
http://www.fordification.com/tech/image ... rake01.jpg
^^ parts diagram 1 shows the 'missing' cable running into a pivot assembly (2A605), which attatches to the yoke which carries the 2 rear cables
BUT
http://www.fordification.com/tech/image ... rake03.jpg
^^ parts diagram 3 shows the 'missing' cable running directly into the yoke 2A602 - then into the rear cables
my good friend ritchie who is helping me sort the truck out has told me that the f250 won't need the pivot assembly shown in diagram 1, as the parking brake pedal provides the effort for applying the rear brakes - what do you guys reckon? - I don't want to source all of the linkage in diagram 1 if I don't need it! - why does 1 diagram have the linkage, and not the other??
sorry for all the ridiculous questions!!
kevfromwales
Postby kevfromwales » Fri Feb 19, 2010 5:13 am
and yeah 2853 is the same cable in both diagrams, so as you said fordman, I'd better get that bit ordered!!
cheers! - kev
Postby fordman » Fri Feb 19, 2010 5:24 am
the first diagram is probably the right one. here is a old photo i have of the secondary short cables you need the rod and hold as well as the adapters fromt he short cables to the rear cables.
kevfromwales
Postby kevfromwales » Fri Feb 19, 2010 5:34 am
cheers fordman - the yoke that I have is totally different to that one - I'll snag it later and get some pics up on here for reference
- not going to get much done this weekend on the truck, as it's a fibreglassing workshop / beer drinking session in bristol for me!
- kev
Postby fordman » Fri Feb 19, 2010 6:01 pm
i'd like to see that.
kevfromwales
Postby kevfromwales » Wed Feb 24, 2010 3:57 pm
okay fordman - here's the yoke I have - each rear cable I have has a spherical nipple, wich fits into each outer hole on the yoke
Postby fordman » Wed Feb 24, 2010 11:11 pm
wow that is different. i am think ing maybe you have the front cable that has the hole in it for the spring to fit into. that is a good cable to have if you upgrade to a inframe aux petrol tank.
mr_josh
Postby mr_josh » Fri Feb 26, 2010 10:22 am
Since your username says that you're from Wales, I'm thinking that maybe you're actually in Wales, and that raises the question: is this truck right-hand drive? If so, it's possible that some parts like the parking brake linkage are different than a LHD truck (I don't know if the factory made any RHD trucks of this vintage... anyone care to chime in?)
Josh
'72 F-100 Sport Custom 4x4
Postby fordman » Fri Feb 26, 2010 3:04 pm
good point maybe the aussie's have similar parts on thier trucks.
Postby fordman » Sun Mar 07, 2010 9:44 pm
look what i just found in my boxes of stuff. i think this may have came off of a newer truck than ours. maybe a 73-79 truck here in the usa.
kevfromwales
Postby kevfromwales » Mon Mar 08, 2010 10:43 am
thanks guys - not been on here for a while, had a big swapmeet hetre, so been sorting out for that to raise some funds!
the truck is left hand drive, it came over from the usa in 1977
that ^^^ bracket looks very similar to mine indeed, and tying in with the 'later truck parts' theory, I looked under a mid 70's F350 at the swap, and the primary e brake cable ran into a stop on the cab mount, then into a similar yoke arrangement
off work tomorrow, so I'm going to try and drill the floor, and start getting this figured - especially as I have to use the truck soon to deliver a lathe!
- kev
