Bypass Voltage Regulator
FordTruck
Post by FordTruck »
Since the wiring harness swap I can't get my volt gauge to say its charging. It worked before I swapped harnesses so I was wondering if my voltage regulator isn't the right one so can I bypass it? The weird part is I haven't had a dead battery yet so any help?
"Flyin High On Caffine And Copenhagen" R.I.P Chris LeDoux
60 Mercury Comet
65 Ford Econoline
72 Ford F100 on 79 4x4 SWB frame
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
Re: Bypass Voltage Regulator
no you cant bypass it you need it. when you started mixing and matching harness the wires dont always go to the same place or some arent even present. the harness you got was probably for a truck with lights instead of guages.
FordTruck
Post by FordTruck »
When I changed harnesses I used everything,all of the other trucks switches,and instrument cluster also my volt gauge is an aftermarket. But anyway I figured it out I pull the alternator off and had it tested and it came back no good so I guess I'll start with a new alt.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
my bet is that the guage is bad .
