what is under padded dash?
Kurt Combs
Post by Kurt Combs »
I was thinking that I might just remove my 72 bump's padded dash and go with all metal. Does that dash look ok under all that padding and vinyl?
Kurt
1972 F-250
mljjones67
Post by mljjones67 »
I like it without the dash pad. The mounting holes are kind of an eye sore. But a good upgrade. And the paint is usually like knew under there.
Do it you will like it
kaptnkaos
re: what is under padded dash?
Post by kaptnkaos »
Here ya go Kurt...
click on pic to enlarge
That's what's under the pad...
KaptnKA 8) S
Washington...The land where rust is like the family pet...Ya learn to live with it and clean up after its mess... KaptnKAOS
"Olde Skool" '68 Ford Bluebird short bus
"FRODO" '68 F-250 Camper Special project
l1k2gadd
Post by l1k2gadd »
My Bump was "Dashpad-less" when I got it. I believe the sun faded the heater control illumination plastic from all of the exposure to the southern sun because it looks whit-ish with the headlights or parking lights on. My instrument panel lights are whit-ish colored too (unless they are supposed to be), not green-ish like all of my other vehicles. I found one of those carpet dash-mats in a '72 that had a Semi-Holes embroidered patch in the center section of it that I removed from it. I think the dash looks better covered. I am inactively looking for a good dash pad for mine and when I find one I will remove the dash-mat.
Too many projects, too little time, but.. lovin' it!
2-1966 Mustangs (one 289-2V and one 200 6 Cylinder),
1-1990 7-Up 5.0 Mustang LX Convertible (second one),
1-1990 7-Up 5.0 Mustang LX Convertible (third one, for parts only)
1-1990 7-Up 5.0 Mustang LX Convertible (fourth one, best of the bunch).
1-1992 "FEATURE" 5.0 Mustang LX Convertible (only one)
1-1993 "FEATURE" 5.0 Mustang LX Convertible (one of the yellow ones)
i had a part truck that had 100.00 dollar bills unde the dash pad. they had purple ink all over them. they must have been from a bank robbery.
SteveC
Post by SteveC »
that sounds a little to far from the truth :o :wink:
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
would you believe some of them had what looked like blood on them? there was also a hugh canvas sack behind the gas tank with a dollar sign on it. but it was empty. :lol:
Kurt Combs
Fordman, I will run out and look under my dashpad asap....just in case. :D
Kurt
1972 F-250
1971ford
Post by 1971ford »
and if you decide to go without a dash pad, make sure you tear the defroster vents out of the dash pad and use them on the metal dash. they have screw holes and everything to put them on the metal (did ford make the screw holes purposly for people not wanting the pad :? )
here is what my 71's looks like:
i think it looks awesome without the pad. id weld up the wholes but i dont have paint.
-Ryan
Teacherman
Post by Teacherman »
I found a ballpoint pen my mom stole from the government when she used to work for Social Security years ago under my original dash pad. It still worked.
I stared at the dash for about 10 minutes without the pad, but I decided to put a pad on it.
1972 F250 Crew Cab
Family heirloom
Photo gallery: http://www.fordification.com/galleries/ ... ?cat=10482
Underdog97
Post by Underdog97 »
Some of us get all the breaks, I wish I'd of found $100.00 bills lining the underneath of my dash pad, all I've found so far has been petrified ants and a couple of bee carcasses. Fordman must've got DB Cooper's old Ford truck, And we wondered where he hid all of that money from the Hijacking, it was under Fordman's part's truck dash all these years (LOL) Can I come over and check behind the gas tank?Please!
MadMaxetc
Post by MadMaxetc »
I have mine off and like it, but I would put a nice one on if I found one.
You also might want to check to make sure it is legal to take it off in your area. Some placees require it, as it was there for safety. (head impact)
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
ezernut9mm
Post by ezernut9mm »
i think it would look good if those big a$$ slots wern't there. also a good condition non-cracked pad just makes for a good looking interior. imho.
kilog55
Post by kilog55 »
so how do you remove it? cause mine has the big crack in the middle and the PO tried to fill it in with something that now looks like sheetrock/drywall
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
1971ford
Post by 1971ford »
I hope you have small hands lol
there are just nuts holding it in. but, theres a bunch. scattered on the underside of the dash, there are many nuts that you just have to get to with a wrench. there is one hard to find hidden nut on each inner corner of the pad on the drivers and pass. side. dont forget those.
i think there are 14 nuts.
-Ryan
