'78 Bronco frame under a '69 F100
wmscott
Post by wmscott »
I found a 1969 F100 swb sitting on a 1978 Bronco chassis. Is the '78 Bronco frame compatible to fit under the '69 F100 body without doing lots of modifications?
cep62
Re: '78 Bronco frame under a '69 F100
Post by cep62 »
:wel:
Welcome to the site.
The Bronco wheelbase is about a foot shorter than a short pickup.
and you may need to fab some rear cab mounts , but the front will bolt up.
wmscott
Post by wmscott »
Thanks for the info. So I'm assuming the frame needs to be lengthened?
cep62
Post by cep62 »
wmscott wrote:Thanks for the info. So I'm assuming the frame needs to be lengthened?
Or make a really short box , those look cool.
In 1973 the rear of the frames got wider than the earlier trucks.
Instead of lengthening the Bronco frame ,
you could graft a '67-72 rear frame to the front half of the Bronco ,then you'll have only one splice to weld.
