Starting problems.
Mcyoung4
Starting problems.
Post by Mcyoung4 »
I have a 1970 f-100 6cyl motor is a 85 ford
I had her running then went to start it turned over then just stoped. Now won’t turn over and the light won’t turn on
The batter is new and good.can anyone help me out ??
Ohiotinkerer
Re: Starting problems.
Post by Ohiotinkerer »
This is gonna sound dumb but reclean the battery posts and terminals with a little 200 grit sandpaper - I changed the battery in mine and 2 days later it wouldn't do anything until I did that.....easy place to start...... :D
1997 Honda CBR 900RR
Jacksdad
Post by Jacksdad »
I second that. Check your battery terminals and grounds.
Mcyoung4
Post by Mcyoung4 »
I wish it was that but it is not I did that and still nothing.
bluef250
Post by bluef250 »
I suggest that you pull the battery and have it load tested.
Mcyoung4
Post by Mcyoung4 »
Thanks all the grounds as stated were not too good :fr:
