Question from a dumb swede...
JohanNB
Postby JohanNB » Mon Jun 19, 2017 11:47 am
Hi there.
First of all, Im a Fordification-member from Sweden so please excuse my spelling and English...
I have a Ford F-250 1970. Every now and then when I try to start the truck it won't start, completely dead. Ive checked the start engine and that one is working. If I move the gear shift back and forth a couple of times it often "solves" the problem... So my question is, could it be the ignition switch or the ignition cylinder?
Re: Question from a dumb swede...
Postby Ranchero50 » Mon Jun 19, 2017 1:00 pm
JohanNB wrote:Hi there.
Welcome. I'll assume the truck has an automatic transmission? If so then the neutral safety switch needs adjusted. It mounts to the top of the steering column under the dash and will have two wires for the reverse lamps and two for the starting circuit. Just loosen the two mounting bolts and slide it to the desired position. Your truck should start in 'park' and 'neutral'.
Good luck.
Builder of dreams, breaker of hearts. Play nice or go away.
tsherry
Postby tsherry » Mon Jun 19, 2017 10:59 pm
Neutral start switch, no doubt. Five minute fix.
or, money.
crazyhorse
Postby crazyhorse » Tue Jun 20, 2017 2:38 am
:yt:
Mr JohanNB, :wel: to the best site period. :fr:
Hope you like it here. :pray:
Pull up a chair and stay awhile. :pop:
JohanNB
Postby JohanNB » Tue Jun 20, 2017 3:38 am
Thanks a lot, it worked!!
Postby sargentrs » Tue Jun 20, 2017 4:13 am
:wel: from Georgia! It's right here.
1970 F100 Sport Custom Limited LWB, 302cid, 3 on the tree. NO A/C, NO P/S, NO P/B. Currently in 1000 pcs while rebuilding. Project thread: viewtopic.php?f=22&t=59995 Plan: 351w, C4, LSD, pwr front disc, p/s, a/c, bucket seats, new interior and paint.
1964 Ford Fairlane 500. 289/Cruise-O-Matic, A/C, P/S.
JohanNB
Postby JohanNB » Tue Jun 20, 2017 7:09 am
Thank you so much for the help!!! It worked!
colnago
Postby colnago » Tue Jun 20, 2017 12:39 pm
JohanNB wrote:First of all, Im a Fordification-member from Sweden so please excuse my spelling and English...
Guaranteed, your English is better that my Swedish! :lol:
:wel:
"Sugar", my 1967 Ford F250 2WD Camper Special, 352FE, "T" Intake with 1405 Edelbrock, Duraspark II Ignition, C6 transmission, front disc brake conversion.
hot-rod
Postby hot-rod » Wed Jun 21, 2017 2:59 am
:wel: @ JohanNB from Germany
@colnago; after 4 or 5 moonshine your Swedish will be perfect Image I have tested it myself Image
Return to “Electrical & Wiring”
Who is online
