Battery was hooked up backwards
77 ford nightmare
Post by 77 ford nightmare »
Ok i have a a 1977 f250 and a little while ago the vattery was hooked up backwards well it fried several things and i have been replacing wires and solenoids and seitches and now i have everything working except the headlights in the dash behind the instrument cluster i found one more burnt set of wires having a hard time figuring out what this is can someone please help
in lower right corner there is 6 wires coming into it and two wires that loop back into the plug
Nitekruizer
Re: Battery was hooked up backwards
Post by Nitekruizer »
Do you mean the part marked 14401 in the diagram?
