Backup lamps not working
shortbedCUSTOM
Post by shortbedCUSTOM »
Well, after sorting out my taillight issue it's time to move on to the backup lamps. I've read thru quite a few threads on here about how to remedy this and most of the threads point to the safety neutral switch, but after looking into my truck I became aware that my truck doesn't have a safety neutral switch. I've looked at the end of the column (engine bay), and under the dash. I don't see it. Is there somewhere else it could be?
My truck is a '68 Ranger. 302 with an automatic. Column shift.
-carlos
Re: Backup lamps not working
Unless something's been swapped or modified, it sure be here http://www.fordification.com/forum/view ... hp?t=53527
MadJoe
Post by MadJoe »
Agreed, it's really obvious. When I was looking for mine because the lights came on between P and R, I set my parking brake and moved the gear selector while looking under the dash... then proceeded to slap myself in the forehead when I realized how obvious it was and hadn't needed to go through all that.
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
shortbedCUSTOM
:doh: :doh: well after a little closer inspection, and a better flashlight, there is a rectangular cut out on the top of the column about 6-8" from the firewall.
-carlos
shortbedCUSTOM
Wow, I just went thru a couple of my catalogs and these things are $100+. Gonna have to hit the salvage yards soon.
-carlos
RustRed
Post by RustRed »
!!!What is that in the photo?
Wanna-be Rat-Rod: 1971, F-103, SWB, 302, 3 Speed on Column, Holley 7448-2, Headers without mufflers,
Planned Upgades: Holley 1850, Alum. Intake, Lighting Heads, Airbrushed Hood etc...
"On a not so quite night u can hear my Truck Rust!!!!"
shortbedCUSTOM
That's the mounting holes in the steering column for the neutral safety switch.
-carlos
shortbedCUSTOM
AWESOME!!! Thanks a lot!
-carlos
MadJoe
Post by MadJoe »
Related question: Is my neutral safety switch only supposed to allow the truck to start in Neutral, or is it also supposed to work in Park? Because my truck only starts in Neutral (1971 F-350 DRW) which isn't a big deal, it passed inspection anyway, and it's sort of like an anti-theft ignition kill switch in that no one seems to know that it works that way until I tell them, but because I'm lazy and a creature of habit I'd like to be able to start it in Park if I could.
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Should start in park also. Try holding up on your shift arm while you try to start it. If it starts, the NSS needs adjusting. If not, suspect a wiring issue.
