heat gauge not working
Junior Knight
Post by Junior Knight »
the gauge was working till the wire got on the intake..so i put the wires back together, installed a new heat sender in the intake, it still wont work...what am i missing? :?
1967 Ford F-100...goin back *STOCK*..just sayin
Busboy
Re: heat gauge not working
Post by Busboy »
Is the oil pressure gauge working? They have the same power source. If it is then you have eliminated that as a possible source of trouble. Need to ground the temp sender wire and see if the gauge responds. If nothing then I'd pull the cluster out for inspection.
1967 F-100 4x4 custom cab.
Junior Knight
have done all of that...nothing..
Busboy
Post by Busboy »
So does your oil pressure gauge work?
KulpFarm
Post by KulpFarm »
Sorry for jumping in here. I have the same problem and both heat and oil gauges not working. Where is the power source for both these gauges?
I didn't know they had common power source.
Busboy
Post by Busboy »
http://fordification.com/tech/wiring/wi ... gauges.jpg
The power for both gauges comes from the instrument cluster voltage regulator. There should be a pulsing voltage coming out of it and averaging around 5 volts I think. You should have this voltage at 30 A and 30 B with the key on.
Junior Knight
just checked the oil gauge..its not working either..ordering a new ivr...thanks for the help
