Tach conversion in a f 600 cluster
1968f250429
Post by 1968f250429 »
Hello all, I was wondering if anyone who has put a cluster from the F600 in their trucks that had a factory tach in it.
If so whom did you use to convert it to electric? I found several places that do this but wanted some opinions of others before I send mine off. Pictures would be great also to see the difference between different peoples work.
Tell about how you like the conversion, does it perform as it is supposed to? How easy is it to do this yourself?
I also have a nos gauge that had a wire come loose and was wondering who I could send it in to have it repaired. As it's not just a normal soldier that holds it. It looks like a brownish color glue or something. Thanks for any help on this.
69Ford
Re: Tach conversion in a f 600 cluster
Post by 69Ford »
The brownish color might be just the flux they used when soldering. Sometimes the flux hardens over the years and looks like glue.
69Ford
Post by 69Ford »
Here's two I would like to have converted called several different shops that do this type work cheapest was around $200 bills. So know I'm looking for a used electronic tach and convert myself.
71PA_Highboy
Post by 71PA_Highboy »
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
71PA_Highboy
duplicate... sorry
Got Ford?
1 Lincoln Mark VIII
