when I jump the solenoid it keeps turning over
seventytwo
Post by seventytwo »
HELP! I drug home my dream truck swb 72 bump from nebraska and I have gone thru the brakes got a new starter solenoid and volt reg the ignition switch is lyin on the seat I need to know what wires go where on the 6 pin switch and when I put the positive cable on the battery it starts to turn over on its own Im tryin to get it ready for carcraft show in july you guys are so good at helpin thought I might strike a vein of knowledge and get some help thank you for your time and info
thanks for the pics I now realize that i am missing the plug for the back of the switch ordered one from the local parts store. really! thanks for all the help I really do appreciate it
love my hot rod ford
Re: when I jump the solenoid it keeps turning over
seventytwo
thanks but I have the 6 plug isnt that different? I know it says 72 diagram not sure and can anyone tell me why/ how to post a pic?
Thunderfoot
Post by Thunderfoot »
Check out this Post/Topic for info on wiring up the switch. http://www.fordification.com/forum/view ... 22#p533822
On posting pictures you need to use something like Photobucket to host the pictures from, facebook wont work... Follow the instructions here http://www.fordification.com/forum/view ... 16&t=22288
Shayne
first picture 1969 wiring.
second picture 1976 wiring.
third picture is of a 1972 full gauges ignition switch plug.
all the 70-72 will have 6 spades that the plug plugs onto. i am not sure if all the terminal spades are used in all the 70-72 plugs. they may be. i didnt look.
seventytwo
seventytwo
fordman wrote:first picture 1969 wiring.
thanks again fordman got my plug today and all wires were black without your pics I woulda been bummin thank you again
