1967 f100 running lights
- randyvines
I have all lights operational but when I pull the switch from running lights to head lights the running lights go out does this sound like it warrants a switch replacement?
Re: 1967 f100 running lights
that is normal operating. that is the way it is set up. you cna change it with a jumper wire if you want though.
- randyvines
I had hoped that that was the case, Electrically this old truck is remarkable and it just seemed out of place that this particular item was an issue. My 14 year old and I will feel much more confident taking in for inspection. We are on a journey building this for his first vehicle. Thanks
The '67-'69 pickups' parking lights are designed to turn off whenever the headlights are on. Beginning in '70, due to 'new' Federal safety regulations, a wiring change made the parking lights stay on with the headlights. The change was in the wiring harness, not in the headlight switch, which remained the same from the previous year and also by going to a dual-filament socket with the front parking lights. You can add a simple jumper wire between two terminals at the headlight switch harness to accomplish this on a '67-'69 truck.
- 70_F100
Keith, I think you're wrong about this.FORDification wrote: The change was in the wiring harness, not in the headlight switch, which remained the same from the previous year and also by going to a dual-filament socket with the front parking lights.
If the parking lights and turn signals were in the same light, the socket would have been dual-filament all along. Should take an 1157 bulb.
Correct me if I'm wrong!!
That's not an oil leak That's SWEAT from all that HORSEPOWER!!
- SteveC
its a dual filament bulb. just on the 67-69s the wiring harness is slightly different.
Ive actually been pulled over due to this cause of no front park lights. after a little explaining and showing the officer that they infact do work perfectly fine i was let go with no ticket.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- Thunderfoot
and They have always had a dual-filament bulb. That is why you can just jumper it like in that diagram and it will make them stay on all the time.
Shayne
I just did this jumper wire mod. last weekend.I used about a two inch piece of wire and crimped an eyelet on each end to make it fit tighter in the back of the plug in.Works great.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- Chaseman
My car is the same thing. Course it's a tad older being a 1966
So I just want some clarification before I try this. The jumper wire should be done on the headlight switch wiring socket.... The back of it... So the wire should be pushed into the back of the socket and contact the "plugs" of the brwn and blk/yllw wires?
I'm a visual kind of guy so actual photos of the mod would be great.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
i think the best way might be to use a flat spade connector on each end of the jumper and stuff it down in the plug slots with the other connector.
- Supermike
I did this a year or so ago, because it annoyed me that it went off and the more lights I have on the truck, the better. Though there is a dual filament, there's a reason at the time they were called PARKING lights. They were more for marking purposes than any kind of fog-light type function.
Using Keith's diagram, I did exactly what fordman suggested... made about a 3" jumper with spade end at each end, then jammed it into each of the appropriate slots. I found one slot was a little loose, so I used my needle-nose pliers to give it a slight "bow". That worked perfectly. Results were this...
Former owner of a '67 F100 Camper Special
Current owner of a '06 F150 King Ranch 4x4 SuperCrew
Not seeing any image Supermike. Is it me or do other people not see one?
Thanks,
Patrick
Thanks,
Patrick
Chevrolet
- Thunderfoot
I see it just fine...
Shayne
- Supermike
Interesting... it's always worked before?mrsnicks wrote:Not seeing any image Supermike. Is it me or do other people not see one?
Thanks,
Patrick
Try this site link, instead...
http://thoughtnot.net/wp-gallery2.php?g2_itemId=611
