curious lighting issue not bump but still ford.
Moderators: Thunderfoot, FORDification
Postby rjewkes on Sun Nov 15, 2009 9:49 am
my 89 merc will flash the parking lights on and off randomly  after sitting for a few days.
Any body know how to explain this? i have also noticed that at wierd times i have daytime running lights  regardless of weather or lighting conditions. And the rest of the time it's normal. Did 89's have any remotes that could pick up a stray Infrared signal and trip the lights?
'70 f250 4x4 Crew cab 460/C6 '72 F100 390/C6 9.8 MPG AVG. '89 Mercury Cougar LS Dual Exh. V6 Digital dash. 18.9 MPG AVG. In Town.
Check out my fuel mileage at http://www.Fuelly.com look for rjewkes. you can even start your own profile and watch your own mileage.
Proudly Boycotting All Boycott's. To truly hurt those being boycotted, you must hostily take 'em over and force them to do what you want.
rjewkes
Re: curious lighting issue not bump but still ford.
Postby TheEskimo on Sun Nov 15, 2009 1:27 pm
I know some Cougars came from the factory with alarms that could flash the parking lights, but I don't think it went back to '89. The headlights switch doesn't use a relay, so all the power goes through the switch. This causes a lot of switches to overheat and fail.
Wait, I think you are saying they are flashing while the car sits, and not in use. That would be odd  :hmm:
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
TheEskimo
Postby rjewkes on Sun Nov 15, 2009 7:31 pm
yeah  it's when it's sitting. Does it mostly during the wee hours of the day when it's  twilightish or so. I does have a remote start that is halfway disconnected. I know on the F650 Wrecker the remote start would turn the lights on.
rjewkes
Postby TheEskimo on Tue Nov 17, 2009 8:00 am
Now that is odd, I checked for a while over at TCCOA but didn't come up with anything quite like that. I will take another look in a few days when work settles down, it's the only time I have to look stuff up latley.
-Jason
TheEskimo
Postby TheEskimo on Wed Nov 18, 2009 7:09 am
Interesting, I can't find anything anywhere about this one. Unless there is a lighting control module, but I don't believe those are used in these cars. At least I ain't found one in my bird yet.
My guess would be something with the remote start, I think a lot of those units turn the lights on so you know it started.
-Jason
TheEskimo
Return to Electrical & Wiring
Who is online
Users browsing this forum: No registered users and 1 guest
