inginition cylinder again
cathynkeith
Post by cathynkeith »
Ok I'm dumb, I got it out, now how does it go back in? I lined up insides, done every thing I can think of (accept throw it across the room) :dk:
P.S. This is the key cylinder back into ing. swich I'm talking about.
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
the shiny pin holder goes up and i think you have to start in the acc postion. thats the way it comes out.
hardtailjohn
Post by hardtailjohn »
Sounds right to me, and I also left the piece of safety wire in the hole above the key until I had it in there...
JH
Never trust a grinning idiot holding a big hammer!
cathynkeith
so its kinda like my wife, gota push the right button to get it in :)
thank you.
1969 f100 flareside
jzjames
Post by jzjames »
*"To install: insert a screwdriver into the lock opening of the switch and turn the slot in the switch to the full counterclockwise position."
Chilton Pickups 1965-86
p.282
kid
Post by kid »
Yep full counter clockwise and if you removed the key from the lock you have to insert the key and wire and rotate the tumblers to the same full clockwise position. Then stick it in.
