Fuel sending unit ???
67highboy
Post by 67highboy »
I was wondering if anyone knows if there is a difference between the earlier tank senders like 59 64 to ours.
Can I use one in my 67?
I believe mine is dead because I can ground the lead to the unit and the gauge climbs as normal but if you hook it to the tank, Nothing.
I've tried grounding the unit thinking maybe it was a ground problem but still nothing. :cry: :cry: :cry:
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
derek7871
Post by derek7871 »
Sounds like mine did. If I grounded the lead, the gauge went to full. Turns out the brass float had a crack in it where attaches to the rod. Naturally, it filled with gas and it sunk to the bottom of the tank sending an empty tank signal to the gauge. If it is the float, there's a guy on ebay that sells them for $5 plus about $4 for shipping.
gonzalo medina
Post by gonzalo medina »
you could use the 61-72 sending unit's a long as they are from the cab gas tanks that 18/19 gallons.
Galaxie64
Post by Galaxie64 »
http://www.fordification.com/fuel-sending-units.htm
should tell you everything you need, mine was bad and the little wire in the unit was broken.
'68 F150 2wd
'72 F250 2wd Camper Special (400/C6/4bbl)
'64 Galaxie 500 (3524bbl/57K miles)
'92 Grand Marquis (mostly stock 4.6L)
'97 F150 (heavily modded 5.4L)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
** Chuck Norris has counted to infinity -- twice. **
67highboy
Post by 67highboy »
Ok,
I pulled the unit tonight and there is no resistance so I guess the rheostat in the unit is bad.
I was hoping the float had turned into a sink but it didnt, just my luck...
so I am looking for a sending unit.
Anybody got an extra? :D
Ben Franklin 1775
derek7871
Post by derek7871 »
Sorry to hear that it wasn't the float. I suppose that's the easiest fix. LMC has a sending unit for $40-$50 best I remember. Good luck.
Galaxie64
Post by Galaxie64 »
I think someone on here is selling on with some ebay stuff IIRC, maybe Fordman.
http://cgi.ebay.com/ebaymotors/67-68-69 ... enameZWDVW
Not sure if a member is bidding on it or not.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
67highboy
Post by 67highboy »
Thanks all :D
Ben Franklin 1775
yes thats me
