Electrical Connector tools
1970pickup
Post by 1970pickup »
Can someone give me a source to by the tools to remove the pins from the plugs used on a 1970 F-100. I have seen some places selling tools but they are not the right size.
Thanks Jack
bluef250
Post by bluef250 »
Which connectors? The Ford are 0.187" and, as far as I know, just pull apart (gently). I use a small flat driver (jewelers) to separate the pins from the column.
heep70
Post by heep70 »
:yt:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
flyboy2610
Post by flyboy2610 »
That's what I use, too. Use the screwdriver to depress the tab on the back of the pin, then gently pull the pin out of the connector.
Red Green
you'd better be right.
