Engine cuts out
kid
Engine cuts out
Post by kid »
After setting for a few months during the front end rebuild the engine started fine but as I go down the street the engine turns off and on. Sometimes it comes back if I turn the key off and on while in gear and coasting (new 6 month old switch and new coil and points plugs and wires 9 months ago). Sometimes it just seems to miss for no reason every few seconds.
Any Thoughts?
68F250
re: Engine cuts out
Post by 68F250 »
Hmm, if the ignition switch has some kind of cause/effect I'd bypass it first and see if it still does it. Run the truck hot-wired but not too long that you overheat the coil. That's where I'd start.
Barry
kid
re: Engine cuts out
Post by kid »
Thanks I will give that a shot. I have an external resistor because of the previous owner so coil burn won't be a problem
kid
re: Engine cuts out
Post by kid »
I bypassed it after a bad day of cutting out and back on and no problem. So new ignition switch does not fix it. Does anyone know where I can get the ignition wiring harness and connector?
kid
re: Engine cuts out update
Post by kid »
Found the original problem that lead to the bypass wire. Ø16A resistor wire does not work. Plus the terminal connectors in my ignition switch connector don't make good contact.
