Info Needed On Wiring Harness
I have a 1968 Ford F100 and I got a new harness from a 1971 Ford F100 that had no engine in it. It has a Carb. Throttle Solenoid connector. What is a Carb. Throttle Solenoid? What does the wire going to it do?
- ToughOldFord
re: Info Needed On Wiring Harness
It's a small solenoid that mounts on the left side of the carb. It kicks the idle RPMs up when you turn on the AC.
Thank You Very Much I have been wondering what the heck was that and does the wire going to it is it a 12V source constant or ignition or momentarly? hope to hear from you again and thanks again and Later Austin
