Need some values on gauge
spartman
Post by spartman »
Was just wondering if any of you knew what the resistance range was on the oil pressure senders in our trucks that had guages.
I am looking for a sender to fit my gauge and it needs to be the same as a Steward Warner setup. That is 240 at 0 psi and 33.5 at 80 psi.
Thanks guys.
68F250
re: Need some values on gauge
Post by 68F250 »
All senders for our trucks (with gauges) are the same ohmic range.
10 ohms = high hash mark on the gauge
22.8 ohms = midrange on the gauge
73 ohms = low hash mark on the gauge
Barry
spartman
Post by spartman »
Well that took care of that idea. :)
Thanks for the reply barry.
68F250
Post by 68F250 »
You're welcome. Why don't you just buy a Stewart Warner sender? The 0-80psi sender is SW279A.
Barry
spartman
Post by spartman »
Just thought I could luck out and use what ford had provided.
mcmclean
Post by mcmclean »
You have no idea how much those number mean to me.. thanks for posting that. -Chris
68' ford crewcab 4x4
spartman
Post by spartman »
Glad to be of help.
Also welcome to the forums mcmclean
