Gas Gauge
jf100
Gas Gauge
Postby jf100 » Wed Apr 11, 2018 5:26 pm
I seem to have a problem like another user did only when I fill the gas tank up it goes way past the full line and when it runs out of gas it is on a quarter tank. I have replaced the float and the sending unit. Any ideas. Thanks you for any help.
1972hiboy
Re: Gas Gauge
Postby 1972hiboy » Wed Apr 11, 2018 6:55 pm
Adjusting the instrument panel regulator would get the gauge back in range. it will also change the swing of all the other gauges too though.
Rich
1972 f250 ranger XLT Camper Special 390
Dont eat yellow snow.....
jf100
Re: Gas Gauge
Postby jf100 » Thu Apr 12, 2018 7:19 pm
How do you adjust the regulator on the instrument gauges?
Thipdar
Re: Gas Gauge
Postby Thipdar » Sun Apr 15, 2018 4:42 pm
jf100 wrote:I seem to have a problem like another user did only when I fill the gas tank up it goes way past the full line and when it runs out of gas it is on a quarter tank. I have replaced the float and the sending unit. Any ideas. Thanks you for any help.
It would be a big help if you told us what year your truck is, and whether you're running dual tanks, which tank you're talking about, etc.
jf100
Re: Gas Gauge
Postby jf100 » Mon Apr 16, 2018 3:26 pm
Sorry about that 1969 F 100 custom cab Main tank behind the seat. I have 3 tanks 2 of them are disconnected ready to pull them out. Switch is set to main tank.
1972hiboy
Re: Gas Gauge
Postby 1972hiboy » Mon Apr 16, 2018 5:54 pm
jf100 wrote:How do you adjust the regulator on the instrument gauges?
If you pull the dash out and locate the instrument panel regulator on the back. there is a small screw or hex screw on the back side in between the terminals. You turn in or out to get the gauge in the proper range. I forget what screwing in vs out does. I believe screwing clockwise increases voltage and counter clockwise decreases voltage. I will try to find a pic of what if your not familiar with that they are or what they look like.
Rich
Return to “Electrical & Wiring”
