Cab corner repair
Mercury100
Cab corner repair
Post by Mercury100 »
The rear panels are available for repair. The front side of the rear cab corners are not available as repair parts.
What is the repair procedure for these panels?
Make them yourself?
Just weld in a flat repair panel?
[image]441[/image][image]442[/image]
I will look into getting some made.
Any interest in anyone needing some replacement panels?
I’m thinking of getting a long sheet made of the correct form and just cut off the length. Then just pinch flat at the bottom spot weld.
BobbyFord
Re: Cab corner repair
Post by BobbyFord »
Fab them yourself. I'll be tackling this soon.
Ditto or find a donor and cut them out. That's the route I took. Old box trucks are good candidates.
tsherry
Post by tsherry »
Fab it up from a good section of a box floor.
or, money.
Manny
Post by Manny »
This is one i am gonna have to handle as well... Does bed floor fix it well??? actually look right? :?
austin
Post by austin »
I fabbed mine out of a sheet of 12 gauge iirc and I just used basic hand tools, it was good enough for the girls I go with
