Bushing assembly
Bushing assembly
New to the Site. Does anyone sell a kit for the front bushings. It's for a 67 swb thanks.
- 67mann
Re: Bushing assembly
LMC truck also has them. The radiator support bushings aren't cheap tho.
Kyle
Kyle
Thank you, wasn't sure if that was correct. First F100 (1967) and first time removing the front clip. Replacing what is worst to start and doing a CV Swap.
They are a pain to take off. Looks like a stack of big washers and they unscrew apart. If your "lucky" they are so rusted they break apart
Kyle
Kyle
- 67mann
If you can salvage one of(the original) them for measurements and you have some fabricating skills.....you can save some $$$
about 2/3 down the pg is how i did mine http://fordification.com/forum/viewtopi ... &start=210
Thanks, I was able to remove them so a little fab work is in order. Thanks for the tips.
