Paint and primer
1guydude
Paint and primer
Post by 1guydude »
So my truck is a yellow ugly flat primer. Only good time to diy paint around here in wa state is nice spring day or mid summer with no wind. Id like to share my knowledge and what i have as far a compressor and get some feedback.
3/4hp be enough? I was told no cheap guns awhile back when i was probably 16. Also im told all the time i put into prep will pay off. My compressor u have to plug in and out cuz the switch is broke.
Was gonna hand sand or longboard the truck and get a nice thick primer layer. Than pick a color. Lol. Id like to clearcoat as well. Guessing thats standard. This is all after i cut away rust pieces and replace ect. Body work.
Color ideas? I see a lot of these old trucks red, blue, black, or even white and green or diffrent shades of these. Not to many yellows. really like the factory yellow. Its soft and easter looking.
Anyways thanks for reading my rambles.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
Jacksdad
Re: Paint and primer
Post by Jacksdad »
3/4hp is on the small side, but it can be done. Spray guns don't use much pressure but they do need a lot of air, so tank size is important too. If your tank isn't big enough/filling faster enough, you might have to stop every so often and wait for the compressor to catch up. That can cause issues with overspray on adjacent panels that you've already painted, especially with clear coat. What capacity is your compressor?
1guydude
Post by 1guydude »
I think it maxs out at like 80psi and than the blow.off.kicks in. It needs a rebuild like the truck i think. The switch and regulator. Ill post a pic.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Jacksdad
Post by Jacksdad »
What size is the tank?
Lone Ranger
Post by Lone Ranger »
When I painted mine I had to stop every so often and let the air tank fill back up. It wasn't so bad though.
I've always liked the light yellow two tone, where the top and bottom are white with yellow in the middle.
Kyle
Jacksdad
Post by Jacksdad »
I've been watching your build, and the truck came out real nice, Kyle. Good choice on going with the Boxwood Green again - pretty truck :thup:
Lone Ranger
Jacksdad wrote:I've been watching your build, and the truck came out real nice, Kyle. Good choice on going with the Boxwood Green again - pretty truck :thup:
Thanks Jacksdad I appreciate it. I've been watching your build and you've done a lot to yours! I would have been nervous to do the things your doing but your making great progress!
Kyle
tsherry
Post by tsherry »
The cheap Harbor Freight paint guns today are easily equal to the Binks gun that I have from the 1970's...and the parts interchange. I shot my '67 with it, and many other vehicles and it performed fine, with either single stage or BC/CC.
My small compressor (2.5HP) was enough for that gun; I have replaced it with a larger compressor with a larger tank--it performs well too. Anything smaller than the CFM that the 2.5 put out(which I can't remember) would be a nightmare for blending panels and especially CC.
or, money.
Lone Ranger
tsherry wrote:The cheap Harbor Freight paint guns today are easily equal to the Binks gun that I have from the 1970's...and the parts interchange. I shot my '67 with it, and many other vehicles and it performed fine, with either single stage or BC/CC.
The 9 dollar one?!! I've been using an old
DeVillebis sprayer but it needs some new parts. I'll have to pick up one or two of those cheap guns from Harbor Freight.
Kyle
tsherry
Post by tsherry »
I have a couple of them. The 'older' one was about $20; years later I bought a set that included the big gun, two pots and a small touch up gun...for $20. Be sure to get a good regulator and filter/drier. I also bought a large pot and paint hoses so I wasn't carrying a quart at a time over the roof. I could never convince myself to spend the money on a Devilbiss gun (back in the day they were a few hundred dollars), but a friend had one and it was sweet.
or, money.
Jacksdad
Post by Jacksdad »
Lone Ranger wrote:Thanks Jacksdad I appreciate it. I've been watching your build and you've done a lot to yours! I would have been nervous to do the things your doing but your making great progress!
Much appreciated. Unfortunately I lost momentum for a while there (too many projects, not enough time), but hopefully I'll be able to get back into it soon. I have a stack of parts building up, so hopefully I'll be able to get the cab finished and the in-cab gas tank, window and bench seat fitted without too much hassle. I'm sure she'll fight me on something though :wink:
1guydude
Post by 1guydude »
Thanks for ur guys responses. Much appreciated. Ill post up pixs of what im working with but sounds like ill have to get a diffrent compressor. Im a cheapo and will probably hit the pawn shop
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
Idk if anyone can read those numbers on there. Like i said. It builds up to about 80psi and than the blow.off.kicks.in and i loss all of it about unless i run over.
The switch auto off is broken i think as well. It was free.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Lone Ranger
It should work. If your painting it'll take a long time to build up to 80 before it blows. You could hook up a spray gun full of water or thinner and see how much you can blow out before the compressor quits. I had to wait for mine to recharge a few times.
Kyle
1guydude
Post by 1guydude »
thanks lone ranger. I was hoping u would chime in as ur truck paint turned out real nice I think. or at least from wat I can see in pics. Any reasons I shouldnt attempt to paint it myself? I like the tip of using water. Obviously ill test on some sheet metal or something 1st.
btw this is way down the rd. mechanical function and safety are my main concerns right now. Also my main money pits. Price of a decent DIY paint job? I haven't quoted anything or even looked for an auto paint store yet. I like the idea of the cheap gun and decent fittings.
thxs all
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
