Mustang Fuel Tank Install (Pics)
BobbyFord
Re: Mustang Fuel Tank Install (Pics)
Post by BobbyFord »
dantheman71 wrote:I understand about the fuel tank frame, I meant the box bolts themselves, because they cannot be turned from above because they are a carriage head bolt...
...I guess you could just put a regular bolt in place of the originals.
Good observation. I hadn't seen that yet since the bed is just sitting there and not bolted on. It does look like maybe I'll be able to get something up there, maybe flex socket, somehow. I'll have to see. Another option is to weld a nut to the inside and go with a bolt from the top. I have seen some large round Torx-headed, low profile bolts that may work from the top. I actually like the idea of the bed bolts going in from the top anyway. Interesting observation. I'll let you know.
BobbyFord
Post by BobbyFord »
After a little research, it looks like I could use new style Ford truck bed bolts. They go in from the top and have a nice attached washer. The new bolts utilize a clip nut that clips on the frame, I think I'll just weld the nuts on to my frame.
dantheman71
Post by dantheman71 »
My 2008 F-350 has the large torx headed ones you mentioned. They would look good.
I haven't started putting my tank in yet but I did buy it, hopefully get at it this weekend. I have to ask these dumb questions because my own truck box is at a body shop 4 hours away right now.
If a person went with the 17 gallon you would be able to slide it backward a bit to access the bolts, but then you would only have a 17 gallon tank.....I like longer trips.
This has been one of the most helpful threads ever!! Thanks again.
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
stockr
Post by stockr »
BobbyFord wrote:
stockr wrote:...whats the height on it...
Are you asking for the dimensions of the tank itself?
well i just saw the pic showing the rear view of the tank..
yep...unless i move it up i doubt ill be able to use it... never the less its still some good info...:D
as far as the rear bolts on the bed..to remove/install..
what you can do is add a piece of pipe..weld a nut,round off the square hole on the bed and add some bolts thru the top..
99 COBRA-DAILY DRIVER
95 F150 EDDIE BAUER-BAGGED
94 BRONCO EDDIE BAUER-FISHN TRUCK
71 F100 SWB- HAS BEEN POSTPONED
BobbyFord
Post by BobbyFord »
This is not where I got mine but here is a site that lists the dimensions. I did not measure mine and I cannot confirm that these measurements are correct:
http://www.justparts.com/Partner/1970_F ... 95184.html
There is not very much room to raise the tank with my type of install and tank model. Earlier tanks are less capacity and have more room on the top side of the tank. The 22 gal. tanks make up the extra gallonage on the top side of the tank. The earlier tank (20 or less gal.) might work for your application.
stockr
Post by stockr »
BobbyFord wrote:This is not where I got mine but here is a site that lists the dimensions. I did not measure mine and I cannot confirm that these measurements are correct:
good deal..
ill check that out in a bit...thanks.. :thup:
Thunderfoot
Post by Thunderfoot »
Nice work! Looks great and very clean install :thup:
Another option on your "Thumb Grab" would be to put it as an indentation in the bottom in front of the door (see pick below) so that you wouldn't have it sticking up to catch on something sliding it in the back. Just a different way at looking at it. :) :2cents:
Shayne
BobbyFord
Post by BobbyFord »
Thunderfoot wrote:Nice work! Looks great and very clean install :thup:
Good point on the thumb grab! (Damn, why didn't I think of that?) This truck is going to be 525HP very soon and I don't plan on ever carrying anything in the bed. I have another truck to use to haul stuff.
Thunderfoot
:lol: Yeah, I kind of thought the back wouldn't get used much in yours, my shorty will not get used much when done either. :) I got 2 other trucks to haul with :D
But mine wont have your kind of HP either... :(
Shayne
Quick69
Post by Quick69 »
thanks for the great write up, this is on the todo list for sure
1971 F100 Ranger XLT
302/C4/3.25
3/4 homemade drop
Wolf0r
Post by Wolf0r »
Subscribed, late but I am doing the same kind of conversion. Good reference and great work man.
http://www.relegalizeindiana.com
1972 F-100 with EFI
1987 Crown Vicky
1990 Crown Vicky
yeager351
Post by yeager351 »
Really glad i found this. Ordered my tank today!
zack
Post by zack »
hey guys, will this work on a high boy???
:hmm: :fr:
1972 crew highboy project
1972 crew highboy 12v cummins daily driver
1970 f250 2wd ranger xlt camper special (first car)
1970 f100 lwb 2wd driver quality
1976 highboy driver quality
etc, etc, etc........
Big Blue 72
Post by Big Blue 72 »
Wow. I wish I had that kind of talent. Nice job!!
BobbyFord
Post by BobbyFord »
zack wrote:hey guys, will this work on a high boy???
:hmm: :fr:
It shouldn't be a problem.
