Mustang Fuel Tank Install (Pics)
Re: Mustang Fuel Tank Install (Pics)
robroy wrote:Hey BobbyFord! I'll bet if you were to produce a batch of those frames you could sell them very easily! I'm sure a kit that would help people implement this rear Mustang tank would be very popular.
But perhaps the time it takes to make each frame would offset the benefits for you?
:yt:
If nothing else, maybe you could post some measurements and such. :pray:
flyboy71
Post by flyboy71 »
You have a pic of where the sending unit is located on this tank? I assume there are no clearance issues with that in this install?
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
BobbyFord
Post by BobbyFord »
70_F100 wrote: :yt:
Heck, I didn't write any measurements down :(
flyboy71 wrote:You have a pic of where the sending unit is located on this tank? I assume there are no clearance issues with that in this install?
No clearance issues of any kind on this fuel tank install. The tank sits well behind the diff.
austin
Post by austin »
looks great good job now you dont have to put up with that tank behind the seat
ares360
Post by ares360 »
Question: is this a gravity feed tank? If not, what did you do?
if it is, have you had a problem with your engine getting fuel?
Kane
1971 Ford F250 4x2, no engine.....what am I going to do?
BobbyFord
Post by BobbyFord »
No problems getting fuel.
Banjo
Post by Banjo »
excellant work, good ideas, where you gonna mount spare tire? Banjo.
Brisco Darlin'......"You sure do render good Sheriff!"
BobbyFord
Post by BobbyFord »
Banjo wrote:excellant work, good ideas, where you gonna mount spare tire? Banjo.
Thanks for the compliments!
No need for a spare tire, I've got AAA Premier :D
In fact, I've never had a flat in my life. I've had leaks but never an all-out flat.
stockr
Post by stockr »
ive been lookn into these for a while..but two things keep me from doing it...
1. im going with and efi conversion...not sure if that sending unit will work..:/ i do have the sending unit from a doner car..i wonder if i can get it welded on top or sumthang...:?
2. im running air bags and i would had to drop it in the back and for the dam thing to catch fire if it scrapes..lol
whats the height on it...
but ill tell you what...i really like the idea...very very sharp...http://www.fordification.com/forum/post ... =7&t=46022
99 COBRA-DAILY DRIVER
95 F150 EDDIE BAUER-BAGGED
94 BRONCO EDDIE BAUER-FISHN TRUCK
71 F100 SWB- HAS BEEN POSTPONED
BobbyFord
Post by BobbyFord »
stockr wrote:...whats the height on it...
Are you asking for the dimensions of the tank itself?
LANCE65
Post by LANCE65 »
I have a couple of questions. On the rear corner tabs,do they sit the tank frame up about an 1/8" or does the whole frame lay flat on the truck frame? Thanks,and BTW looks GREAT!
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..lol :D
BobbyFord
Post by BobbyFord »
LANCE65 wrote:I have a couple of questions. On the rear corner tabs,do they sit the tank frame up about an 1/8" or does the whole frame lay flat on the truck frame? Thanks,and BTW looks GREAT!
-Lance
The tank frame sits up in the rear the thickness of that metal nut hole pictured above.
That is actually the bottom side of the tank frame that you see; that nut hole secures the rear of the tank frame to the truck frame. The rear-most bolt seen below bolts the rear crossmember to the truck frame, the bolt just forward of it is the rear tank frame mounting bolt:
On the sides of the tank frame, where the access holes were made to weld in nuts, flat stock was tacked along the sides to cover up the access holes and add ridgidity and overall strength to the tank frame.
dantheman71
Post by dantheman71 »
Ok, one more question, if you have the box lifted up to slide the tank in, then you set the box down, are you able to get access to the 2 box bolts located just behind the rear axle? Not the ones at the very back underneath, the next set forward. It looks like maybe a set of really small hands might be able to reach over the frame and put a nut on the box bolt??
I plan on having a roll pan so I won't be able to just take off the back bumper and slide the tank out.
Thanks for your help.
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
BobbyFord
Post by BobbyFord »
All of the nuts are either welded into the tank frame or welded to the truck frame so that it is not necessary to get a wrench on the nut anywhere:
dantheman71
I understand about the fuel tank frame, I meant the box bolts themselves, because they cannot be turned from above because they are a carriage head bolt.
I guess you could just put a regular bolt in place of the originals.
1972 Ford F-100
2002 Ford F-150
