69 bed rust repair options
prdjr1
Postby prdjr1 » Sun Dec 31, 2017 3:08 pm
I have a 69 f100 short bed tham i'm getting ready for paint-I came accross this rust when media blasting.it looks might it might have been repaired with lead or something at one time.there is a small 2"x2" metal patch piece attached on the underside of this area that is loose and i slightly pryed it away.my question is if you can tell from the pictures if i should cut this area out and patch it or can i get away with some POR15 and fill it.It's really close to the seam and thats where i'm concerned with patching it.
MAK
Location: Georgia, Blairsville - Florida, Flagler Beach
Re: 69 bed rust repair options
Postby MAK » Sun Dec 31, 2017 3:54 pm
After going to the trouble or expense to blast the whole bed, I would go ahead and cut it out and weld in a patch. Anything else would eventually trap moisture and rust again IMHO.
cep62
Postby cep62 » Sun Dec 31, 2017 8:47 pm
:yt:
ButtaBean
Postby ButtaBean » Sun Dec 31, 2017 11:40 pm
MAK wrote:After going to the trouble or expense to blast the whole bed, I would go ahead and cut it out and weld in a patch. Anything else would eventually trap moisture and rust again IMHO.
True story. I agree.
prdjr1
Postby prdjr1 » Wed Jan 03, 2018 6:00 am
removed the bed yesterday-picking up a welder friday.
LCarter69
Postby LCarter69 » Fri Feb 16, 2018 7:55 pm
I have the same issue, except ive got a small spot behind the seam as well. I'm thinking of putting in a single patch since im smoothing the seam anyway.
prdjr1
Postby prdjr1 » Sun Feb 18, 2018 10:46 pm
by smoothing the seam do you mean welding it ?
Return to “Body & Paint”
