Other options for gas filler location?
Moderators: heep70, FORDification
Postby mrtleavitt on Fri Nov 06, 2009 2:54 am
He guys I'm going to install an after axle gas tank on the '69 which now actually has a '74 frame. I'm trying to figure out a place to mount the filler that will be clean and as hidden as possible. The truck is fully restored so I'm not going to put a door in the side of the bed and the bed has rhino lining so I don't want to cut up the inside of the bed either. Have any of you guys seen a good looking, clean install? I was thinking of tucking it in the fender well some how out of site. Any ideas?
mrtleavitt
Re: Other options for gas filler location?
Postby Joshpow on Fri Nov 06, 2009 6:46 pm
Not sure of a nice alternative to the two you listed.  I plan a bed floor one.  I saw one tucked in the fender well one time, but it really wasnt my favorite.  How did everything line up on the newer frame?  I have heard this is a rough swap.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
Joshpow
Postby mrtleavitt on Fri Nov 06, 2009 7:16 pm
Everything lined up great other than the bed. I moved the leaf springs forward two inches but the bed didn't sit flat on the frame. The frame has a pretty good hump to it over the axle and it hits the bottom of the bed rather than the bed brace. Now that it's all done it's awesome but now knowing how to do it, I wouldn't do it again.
mrtleavitt
Postby FORDification on Sat Nov 07, 2009 9:45 am
Not wanting to put a door on the outside or the inside of the bed pretty much limits your options. However, I'd be a little leery about just hanging it out in the fenderwell, due to the dust, mud and other road debris that'll get thrown up. It would seem to me that every time you go to fill up, you'll have to really clean off the cap area first to make sure you don't drop some of that debris down into the tank.
'67 F-100 2WD SWB ~ '69 F-100 4WD SWB w/7" chop
FORDification
Site & Forum Admin
Site & Forum Admin
Postby 1971ford on Sat Nov 07, 2009 12:46 pm
How about behind the liscense plate? it would take some work, but maybe.
-Ryan
___1971 F250 prerunner # 871 / 1969 F250 4x4 Highboy Full rebuild project
Image Image
1971ford
Postby BobbyFord on Sat Nov 07, 2009 1:05 pm
1971ford wrote:How about behind the liscense plate? it would take some work, but maybe.
If using a Mustang tank the tank would have to be mounted very low to get the filler behind the plate. There aren't too many options when using a Mustang tank.
1972 Sport Custom Short bed 466/C6/3.50 trac-loc
1963 F100 Unibody 390/C6
1967 Mustang Fastback 390/4-speed
BobbyFord
Postby mrtleavitt on Sat Nov 07, 2009 1:42 pm
I have a '74 frame so it's a stock style tank for the dentsides.
mrtleavitt
Return to Body & Paint
Users browsing this forum: No registered users and 2 guests
