Foldsmobile F-250?
Online listings for vehicles only. No parts listings please.
occupant
Foldsmobile F-250?
Post by occupant »
Just saw this on Tulsa CL...had to weigh in on it because it combines two great things. 1) A bumpside pickup 2) a Rocket 350 V8
1968 Ford F 250 Tulsa CL $750
For some reason I don't see anything wrong with this truck at all. It means it should be easy to get running and driving and I can enjoy the truck while I put together some other sort of engine/transmission combination (when I started typing this post I was thinking 351W EFI/AOD for gas, or for diesel, a 6.9 or 7.3, or maybe 4BT/6BT Cummins, but now thinking as it has engine mounts and all to match a GM engine, why not use the 6.2L Chevy/GMC diesel?) to go in there, and I can ALSO make sure that when I'm ready to put said engine/transmission combination in there that I have a 74-77 Cutlass or 77-79 Delta 88 or 77-90 Custom Cruiser wagon ready for a transplant so I can make more good use of that 350/auto combo.
For $750 and a straight body (sans tailgate) and a clean interior and probably not far from running and driving, this may be a better vehicle to focus my efforts on than the beater flatbed or the one in Elk City with transmission issues.
For those who don't know, I have way too many automotive loves in life. First and foremost are 1974-1979 Ford intermediates like Torinos, Montegos, Cougars, Rancheros, and Thunderbirds (have owned two whole, one parts, one I bought and it got impounded before I could tow it home). A strong second are the 67-72 Ford pickups (have owned three). Tying for third are the FWD GM A-bodies (Century, Celebrity, Ciera, have owned eight) and the 77-up RWD GM B-bodies (Impalas/Caprices, Delta 88s/98s, Buick Electras, have owned ten). Tying for fifth are Chrysler F/M bodies (77-89 LeBaron-Diplomat-5th Ave-Gran Fury, owned three), Datsun 210 (79-82, owned three), Ford Tempos with manual shift (86-94, owned two), and Dodge Dynastys (88-93, owned three). Whenever I go looking for cars to buy, those are what I search for first, then I start looking for anything else available in my budget, preferably 70s, then 80s, then 60s, then 90s. And then I have this giant list of other cars I want to own before I die. Stuff like a 71-72 Centurion or LeSabre coupe, 86-89 Fleetwood Brougham with the 307 engine, 72-75 Chevy BelAir or Impala sedan, 74-78 Newport, 74-77 Royal Monaco, 77-78 Monaco, 75-80 Granada, 78-83 Fairmont, 90-94 Town Car, 71-76 Delta 88, and loads of assorted 80s-90s cars I grew up seeing but couldn't afford like 97-99 Maxima GLEs, 90-93 Integra sedans, Eagle Premiers, and the LeBaron GTS/Lancer hatchbacks.
Alan Moore | TOAD Towing | Columbus, OH
00 Suburban "Moose III"
Strong Bad I | Strong Bad II | Strong Bad III
ezernut9mm
Re: Foldsmobile F-250?
Post by ezernut9mm »
i have some stock need to be rebuilt 69 rocket heads for that 350. :D
gregamorton
Post by gregamorton »
I found a 1965 shortbed f100 with a 455 Oldsmobile and auto for $750 the other day. Been sitting there over a year and its 3 miles from my house.
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
occupant
Post by occupant »
gregamorton wrote:I found a 1965 shortbed f100 with a 455 Oldsmobile and auto for $750 the other day. Been sitting there over a year and its 3 miles from my house.
And I just found a '68 with a 455 and a blown motor for $1400. Body is straighter and freshly primed it seems...
http://tulsa.craigslist.org/cto/3693885327.html
Here is the original $750 F250 with a Rocket 350 ad, reposted 3/3:
http://tulsa.craigslist.org/cto/3656800277.html
'69 F250 with a 4-speed and a 2-barrel 302 he thinks:
http://tulsa.craigslist.org/cto/3691090675.html
And my favorite off the Tulsa CL, a 1970 F100 with a 351M/automatic for $400 that runs and drives but needs brakes:
http://tulsa.craigslist.org/cto/3641225595.html
As much as I want a 4-speed, that 351M powered truck would probably be a better start. Get the brakes functional and drive it home, enjoy it around town while I acquire bits. I wonder if it was always an automatic or if there's a clutch pedal sitting on the floor and all I need to come up with is a good 460cid's ZF 5-speed transmission, clutch, linkage, cylinders, and lines, and make the swap. The 351M is external balance 28oz, so no problem there. Worst case I need some manual pedals and brackets. I think it's doable, dude has a voicemail from me now.
