bucket seats
takehikes
bucket seats
Post by takehikes »
I was looking at the original 1968 brochure and the bucket seats look like the one's out of the Mustang. are they? My seat is sad, usable but on its last legs so thought I might go bucket. Especially if they are the Mustang seats as they and their covers and foam are readily available.
1968 F100 SWB Flareside, 240-6, 3 speed, 3.70 rear, bone stock and rust free.
Canonman67
Re: bucket seats
Post by Canonman67 »
Yes they are. You'll also need to get or make the brackets that raise the seat off the floor. Here's a link for the brackets if you decide to make them. http://www.fordification.com/tech/bucketseats.htm Please post pictures of your project, you can never tell what might help the next guy.
Busboy
Re: bucket seats
Post by Busboy »
I've got the complete assemblies for sale that came out of a 68 Ranger. :fr:
1967 F-100 4x4 custom cab.
lilorbie
Re: bucket seats
Post by lilorbie »
i have a set of buckets out of a 67 or maybe a 68 econoline van seat brackets and all. of course they need to be recovered. does anyone know where i could get a upholstery kit? i can do it my self. or should i get a pro to do it? i am going to put them in my 67 f-100. thanks for any help on this.
lilorbie
Re: bucket seats
Post by lilorbie »
took my seats to the local upholstery shop. they tell me they are from a 68 econoline van. they can not be reupholstered. because the foam on the springs is injected around the springs. live and learn still looking for some mustang seats. the local junkyard has 2 mustangs the seats are so far gone that they are seats in name only. the brackets from the van however are in good shape. i can fix them to work with some mustang seats.
HIO Silver
Re: bucket seats
Post by HIO Silver »
'70 Mustang Mach 1 buckets with TMI Sport R foams & upholstery... on factory brackets.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
FFRKing
Re: bucket seats
Post by FFRKing »
On the bucket seat brackets, why does the inner bracket have the 2 3/8" raised tab toward the back of it? Is it necessary? It would be a lot easier to bend up a set of these without it as I have a straight brake but not a finger brake.
I would like to make a set to bolt in my 1969 Cougar buckets to try them out. I'm not 100% convinced that is what I want and don't want to commit to buying any unless I could find a good deal.
Thanks
Chris
-1968 F100 SWB, 4.6 3V, 5R55S auto, Crown Vic front and rear.
-1968 Cougar XR-7, 351C, AOD, Explorer rear. In approx. 6,000 pieces at the moment.
ultraranger
Re: bucket seats
Post by ultraranger »
FFRKing wrote:On the bucket seat brackets, why does the inner bracket have the 2 3/8" raised tab toward the back of it? Is it necessary? It would be a lot easier to bend up a set of these without it as I have a straight brake but not a finger brake.
Thanks
Chris
It's the stop for when the seat slides back on the track.
I'll be putting 1990 Mustang GT seats on my '68 Mustang seat sliders, that will bolt to the bucket seat brackets that will go in my '69 Ranger.
Steve
