Transmission/Transfer Case Issue
4x4 & Off-road Forum Archives
Moderator: Doug Comer
ford4x4fun
Post by ford4x4fun »
My truck is 71 F100, that had the NP 435 with a Dana 21 Transfer Case. Well as most of you know I had a shop jack up my transmission. Well I got a knew NP 435 off of a truck that had a NP 205 Transfer Case. The spline part that hooks into the Transfer case isn't exactly like the NP 435 that hooked to the Dana 21. I just wanted to know if this transmission will work or what I have to do to make it work. Thanks for your time. I wish I would have taken pictures but I forgot my camera while I was home this weekend. And as always thanks in advance.
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
averagef250
Re: Transmission/Transfer Case Issue
Post by averagef250 »
the D21 NP435 is just a 2wd transmission. You will have to upgrade to an NP205 to use the 4x4 NP435 (very wise upgrade).
Wes
Post by Wes »
I'm asking, but is the F100 trans a 2by trans like the F250's? I thought the F100's were mated.
Wes
67 F250 High boy
69 Bronco
averagef250
They are mated, but they use essentially the same NP435 as the 2wd's. It's the same deal when you want to put a 435 in an early bronco with a D20. You buy yourself a 2wd 435 because the shaft and rear bolt pattern on the case are correct.
