1979 to 1972 f-250 parts swap,scavenging
4x4 & Off-road Forum Archives
Moderator: Doug Comer
Postby averagef250 » Tue Aug 07, 2007 1:29 pm
The hood may fit, but is very wrong.
The '79 has a mated tranny and t-case. You can run it if you run the 79 front axle.
Site & Forum Admin
Site & Forum Admin
re: 1979 to 1972 f-250 parts swap,scavenging
Postby FORDification » Tue Aug 07, 2007 6:40 pm
The hood won't work unless you also use the dentside radiator support and hood latch. On our bumpsides, the latch is on the hood and the catch is on the radiator support, but on the dentsides the latch is on the radiator support and the catch is in the hood.
ima71 trucks are older
Postby ima71 trucks are older » Wed Aug 08, 2007 5:10 pm
The 79 has a married transfercase.
Take all of the 78-79 power steering setup. its an easy swap and a lot better design then the '77.5-down
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
Return to “Archives”
Who is online
