D60 rear to D60f
4x4 & Off-road Forum Archives
Moderator: Doug Comer
LANCE65
D60 rear to D60f
Post by LANCE65 »
Can a dana 60 rear be built into a dana 60front?
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..lol :D
willysrul
re: D60 rear to D60f
Post by willysrul »
Yes, Christian Hazel from JP Magazine did one a few years ago("Hazels' Sixty"). Started with a Dodge rear and put all Crane C's and knuckles with all the bling. Came out to right around what you would spend on buying a Dynatrac Front 60. Lots of work, but can be done.
67 HiBoy - 390/435/TS'd205 HPD60f/FFD60r welded 3.54's 36x12.50x16 TSL radials
50 Willys P/U (project) - 302/435/205 FFD60r
Clarko
Post by Clarko »
With a front axle, you usually want a high pinion, too.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
averagef250
Post by averagef250 »
Good point. I really don't understand why anyone would spend as much to turn a rear 60 into a front axle as a dynatrac piece would cost. The dynatrac stuff is top notch. A ******* low pinion 60 front made from rear parts is not worth a whole lot.
