twin stick 205
4x4 & Off-road Forum Archives
Moderator: Doug Comer
willysrul
re: twin stick 205
Post by willysrul »
Dunno? I have never messed with a 24. I would say yes because usage in design is similar but it would be trial and error. If you had a extra set of rails lying around or made some mock up ones to try I would say go for it!
67 HiBoy - 390/435/TS'd205 HPD60f/FFD60r welded 3.54's 36x12.50x16 TSL radials
50 Willys P/U (project) - 302/435/205 FFD60r
ICEMAN6166
re: twin stick 205
Post by ICEMAN6166 »
thanks. i have several of the 24s and one is dissassembled so when i get to putting it back together i will see what can be done.
ChrisB
re: twin stick 205
Post by ChrisB »
I have a twin sticked 205 in a truck I purchased. I've been concentrating on building other things like a flatbed cage, rock sliders and crosmembers. I want to do a full exocage eventually.
I plan to pull the 205 and rebuild or reseal it, possibly add a 203 doubler and or different gears for the 205. I notice everything about the twin stick mod works except for 2wd front high. I am guessing it's something wrong with how the shift rail was ground or the linkage itself. Any thoughts?
willysrul
re: twin stick 205
Post by willysrul »
I followed all the directions from three different articles for grinding down the shift rail. I quit because I was nervous about taking to much off. So I have every combo except front high, which is fine with me. As long as I have front wheel drive and rear low I'm happy.
ChrisB
re: twin stick 205
Post by ChrisB »
Thanks for the input. I'll let you know what I come up with. I'm fine with it as well, nice to have it all though. I'm gonna test the rig for the first time this weekend. After that it's on to other mods, including pulling the 205 and servicing it, or modding, doubling etc.
heep70
Re: re: twin stick 205
Post by heep70 »
NO. I won't work wright. I already checked it out when i swapped my D24 case with another.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
