Largest tire for a D44HD?
4x4 & Off-road Forum Archives
Moderator: Doug Comer
waynaferd
Post by waynaferd »
What's the biggest tire you guys are running on your 3/4 tons? Could I get away with 38's with moderate off-roading and a hefty big-block, and open diff? It's on a 67 F-250....Thanks!!
A 72 F-250 Hi-Boy "project" ( that means sitting untouched for 3 or so years)
And a little 94 F-150 Flareside, 7" higher and 35's...
460 crew
Post by 460 crew »
Not more than a 35 is recommended but If your not hammering it I'm sure you could make it work for a while till you have some carnage, or something wears out prematurely due to strain of the larger tires.
heep70
Post by heep70 »
If you still have the closed knuckle HD 44 the biggest worry is the knuckle casting breaking from abuse. I have seen 38" tires on pavement pounders.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
19674x4
Post by 19674x4 »
i would say 38's max with no hard 4wheeling. i wouldn't go any bigger than 35-37's though. I have 33's on mine but plan to go with 35's :D Just make sure your inner and outer bearing are in good shape and snug. I would also do a routine check of suspension and brake componets, along with your king pins and u-joints.
My Photo Album
bm52
re: Largest tire for a D44HD?
Post by bm52 »
so the around 35's rule applies to say a stock 69 4X4 too right?
1969 F100 SWB 4x4
2001 F150 Sport
1977 Camaro Coupe
heep70
Post by heep70 »
:thup:
Greg
