Charging problem is driving me nuts
phoelsch
Post by phoelsch »
My 70 f100 has a charging issue that is killing me. The new altenator that I put on is only reading 10 volts while in my truck. Bench tested at the parts store and it's getting 14 volts. Replaced voltage regulator and I'm still getting 10 volts. I checked and cleaned all of my connections. Replaced the motor to body ground. Not sure what and the heck is going on. Could I have gotten a bad voltage regulator?
Mohillbilly
Post by Mohillbilly »
That's possible, or you might have the alternator checked again, in case it blew a rectifier inside. A good local alternator repair shop can test the alt/reg together under load.
70 Custom LWB, 302-2V, 3 on tree
Leadfoot
re: Charging problem is driving me nuts
Post by Leadfoot »
likely its something to do with the old crusty field wire or the voltage reg.(like a grounding problem)
WHAT ?
bluef250
Post by bluef250 »
Check alternator belt for slipping. Clean and check ground, including the battery. Check for a bad battery. Why did you install a new alternator?
rjewkes
Post by rjewkes »
got the noise reducer? it looks like a longer condensor.
fuelly.com
phoelsch
Post by phoelsch »
I've narrowed it down to an wiring issue under the dash. I have checked every wire, component and ground under the hood for continuity and every thing has checked out fine. Few busted wires but I tended to them. Altenator is still bench testing at 14 volts. I replaced the altenator as my first shot gun approach to solving the issue. Original alt was probably still good.
