F350 coil springs
- FLATBEDFORD
F350 coil springs
1970 F350 DRW. It seems my truck is listing a bit to the port side. I suppose that after 36 years the springs must be getting a little soft. I've done some searching but haven't been able to find a source for F350 coils. Found lots for 1/2 and 3/4 ton, but none for 1 ton. I know that leaf springs can be re arched. can coils be re...coiled? or what ever it'd be called?
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
My Photo Gallery
- heep70
Did you call a spring shop?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- heep70
You grab one end and I will grab the other.
Greg
- heep70
re: F350 coil springs
TEETH
Greg
- heep70
This is long distance, but maybe they can answer your question on the 350 spring.
Gitt's Spring
Address: 3921 B St NW, Auburn, WA 98001
Phone: (253) 833-6806
Gitt's Spring
Greg
- 72hiboy4x4
- Location: As far away as I can be from Wa state, without crossing the Mississippi
Heating a spring to lower it is actually a no-no!
Yes, that was how it was done a couple decades ago, before anyone knew any better, but heating a coil spring removes the temper and ruins the spring. And once the temper is gone, it will continue to drop, on it's own, over a relatively short period of time. I guess the way I look at it is if you're going to do it, then do it right once....so you don't have to re-do it.
- 390Nut
How about some blow-up sumo wrestling outfits? My sister bought a pair of them for her husband for their 10th anniversaryfordman wrote:ok do you have a tarzan suit so we can look like strong men streching a spring with our teeth?
FLATBEDFORD:
Get in touch with the folks at Eaton. If they don't carry them, they can make them easily. they can also do stuff to specs you supply, for whatever you want.
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- FLATBEDFORD
I think the sumo suits would be best. Remember there is only one Tarzan and many sumo wrestlers.
I'll have to find a spring shop and call them. I just wanted to ask the potentially stupid question of friends first. Actually a spring shop heats the spring to soften and reshape it, and then retempers the spring afterward. I suppose the art is in tempering the spring after the work is done. As I said, I had leaf springs done, just never coils. All my trucks have had leafs all around until this one.
It seems like removing the coils shouldn't be very tuff as long as I use plenty of penetrating oil.
Steve
My Photo Gallery
My Photo Gallery
