CV suspension mods
Twisted_Steel
CV suspension mods
Post by Twisted_Steel »
For you engineer fellas,
Is the CV cradle under the frame a solid piece or is it hollow?
and if it is a solid plate, is it possible to cut a section out of the middle and use steel plates bolted thru the cross member to strengthen it enough to be used for different applications?
SportCustom
Re: CV suspension mods
Post by SportCustom »
It’s solid on the ends where it mates to the frame with a hollow portion through the middle under the engine area. If you look at pics you can see the opening under the steering rack area.
1970 F-100 Sport Custom
390 FE
CV/8.8 Swap
fuzzier1
Post by fuzzier1 »
I belong to a Facebook group that does CV swaps on all kinds of vehicles. There is a guy on there that makes a kit that replaces the aluminum cross member with his own design that narrows the track width of the frontend. It will fit many different vehicles. If you want I can post information about it here. If I hadn't already had my CV installed I would be considering it. Let me know.
Twisted_Steel
Fuzzier1,
PM sent
jamesdfo
Post by jamesdfo »
Team321 suspensions new website has a page with info on their Steel narrowed CV crossmember....
http://www.cocoabeachfab.com/narrowcrownvic.html
James
Twisted_Steel
Thanks James,
I'll give them a call tomorrow.
jamesdfo
Post by jamesdfo »
Just a heads-up: Since I posted the link a couple of posts up, the following thread has appeared on another channel:
https://www.ford-trucks.com/forums/1560 ... s-kit.html
